You might want to consider a 'sill plate' under the joists and the outer board they are attached to(not sure what to call that). That will take the load off the nails and spread the support between the blocks.heathicus wrote:I do plan on doing that. I'm just out of suitable blocking material right now. I'll pick up some more concrete blocks on my next trip into town or see if my dad has any treated lumber scraps when I go out there for Christmas. I was planning 6 blocks along each side.
Shop building questions
It's called a band joist. (I had to look it up!)
A sill plate is a good idea. I'll be sure to use one.
EDIT: i just recalled I did not dimension the band joists to the same width as the floor joists. They are wider so hang down lower than the floor joists by about 1/2" or so.
Heath
Central Louisiana
Central Louisiana
heathicus wrote:It's called a band joist. (I had to look it up!)
Good Boy!;)
The rain broke and my dad came out today and we made some great progress. Got all the walls framed and all the ceiling joists cut. He's coming back tomorrow and we should finish getting the rafters nailed down and all the tin on. Then I'll just have electricity, shelves, unpacking the storage, etc.
Heath
Central Louisiana
Central Louisiana
Only 9" / 12' pitch?
More than enough for water to run off.JPG40504 wrote:Only 9" / 12' pitch?
Heath
Central Louisiana
Central Louisiana
As long as you do not care how long it takes!:D Less wind profile that way.heathicus wrote:More than enough for water to run off.
Since snow is not a problem here, it will run off as fast as it piles on.
Heath
Central Louisiana
Central Louisiana
heathicus wrote:Since snow is not a problem here, it will run off as fast as it piles on.
Really! I thought Amarillo was south of WDN!
https://forum.shopsmith.com/viewtopic.php?p=105627&postcount=26:D
It's not unusual for for Dallas to get snow and that is a lot closer to me than Amarillo. It's not unheard of for Atlanta to get snow. And I mean significant amounts. But here? We might get 1/4 inch every once per decade.
Heath
Central Louisiana
Central Louisiana
