Back in the Machine(ist Chest) Shop
nuhobby
Plywood Processing
Post by nuhobby »
A few more satisfying little steps done today....
I rough-cut the newly veneered plywood and started duplicating factory rabbets on the edge, using the Overarm Router:
[ATTACH]24650[/ATTACH]
Following this I fine-tuned the extents of exposed finish ply-veneer, using the leftover factory veneer as a "story board":
[ATTACH]24651[/ATTACH]
My method has produced a new Back that is 1 ply thicker than what Gerstner used. So I freehanded some relief cuts to facilitate proper mating of internal parts:
[ATTACH]24649[/ATTACH]
Inner Back Reliefs.jpg (101.68 KiB) Viewed 15423 times
Tiny Rabbets.jpg (107.76 KiB) Viewed 15420 times
Veneer Story Board.jpg (91.09 KiB) Viewed 15422 times
Chris
nuhobby
Back Test-fit
Post by nuhobby »
Hurray! Satisfying to see that new back locking into place (old back is lying below).
Not much else done this weekend.... too nice to stay inside!
[ATTACH]24669[/ATTACH]
New Back Test Fit.jpg (107.09 KiB) Viewed 15399 times
Chris
nuhobby
So Long, Metal-Lathe
Post by nuhobby »
Well, I did a little soul-searching. My shop time is only a few hours a week, so last Saturday I handed the Craftsman metal lathe over to a new owner. Those proceeds have been involved in other quests by now....
I have to throw in some "plugs" for the ultra-versatile Shopsmith here. For cutting hole-plugs, it's a very easy setup via horizontal boring. What is a little tricky is experimenting to get the best rpm and feed rate to cut those plugs cleanly...
[ATTACH]24883[/ATTACH]
I also find the "Horizontal Milling" feature to be super-neat for fixing odd jobs. Here is a case of a saw-tote with a chipped-out "horn." Gluing on a new horn via a butt-joint isn't super strong, but gluing in a patch with 2 right-angle facets is a big step better. So, with a setup like this (clamps and backerboards not shown), I can crank the table and mill out just such a "corner" to accept a right-angle patch piece:
[ATTACH]24884[/ATTACH]
A candidate for fixing Saw Tote Horns was the lower of these two Atkins handsaws, a dirty old No. 401 "super premium saw" I scavenged for $8 from eBay:
[ATTACH]24881[/ATTACH]
Below is a picture of one of my worktables now relieved of the metal-lathe, and exhibiting woodworking stuff. The Gerstner chest carcass has 61 hole-plugs just installed. A recently-acquired Lie Nielsen No. 2 plane is at the left. Middle position is a Craftsman No. 3 plane that I made a new curvaceous tote for. At right is the Atkins 401 saw with 2 new "beef tips", patches added to the original rosewood horns.
[ATTACH]24882[/ATTACH]
Back to Woodworking.jpg (105.89 KiB) Viewed 15329 times
Boring Plugs.jpg (93.91 KiB) Viewed 15329 times
Horn Milling Method.jpg (102.09 KiB) Viewed 15332 times
Chris
swampgator
Post by swampgator »
Incredibly FFFIIIIINNNEEEE work. Thanks for sharing this story.
nuhobby
More Stuff
Post by nuhobby »
A "blended" couple of sessions starting work on a new Front Panel (frame and panel style)....
Yesterday evening with no one home I made a bunch of noise on the table-saw, cutting grooves (had my new non-thru-cut Riving Knife there too):
[ATTACH]24963[/ATTACH]
Tonight was a "quiet rule" night with SWMBO grading Finals upstairs. So.... killed some time the old-fashioned ways....
Scribed and rough-cut a tenon with a chisel:
[ATTACH]24965[/ATTACH]
Used my olde German rabbet plane as a shoulder plane:
[ATTACH]24964[/ATTACH]
Tried out the fit:
[ATTACH]24966[/ATTACH]
(Drawing of the frame dimensions in the background.) A long way to go at this rate, but enjoyable.
Grooves on Tablesaw.jpg (96.9 KiB) Viewed 15295 times
Rabbet Plane in Use.jpg (70.88 KiB) Viewed 15293 times
Rough Tenon Chisel.jpg (103.95 KiB) Viewed 15297 times
Test Fit.jpg (100.67 KiB) Viewed 15293 times
Chris
nuhobby
Color palette ???
Post by nuhobby »
Continuing the frame+panel project.... I thought I had a piece of light colored wood just right for the panel. Turns out I was wrong so I gambled on a piece of very special walnut from my pile. I really don't know how this old thing will end up color-wise; after the years of wear the bottom of the oak chest had darkened more than the lid did.
Here's a piece of walnut marked out for bandsaw cutting:
[ATTACH]24994[/ATTACH]
Here I've glued up the frame, 2 corners at a time. I also figured I'd turn it upside down from my original plan... the new orientation is better at hiding some joints that came out a little sloppy:
[ATTACH]24992[/ATTACH]
After the glue dried, I cut the whole assembly down to size and started trimming and installing the metal hardware pieces. Having confirmed the retaining plungers fit the holes I made, it's time for a break:
[ATTACH]24993[/ATTACH]
Frame Glueup2.jpg (104.7 KiB) Viewed 15251 times
Plunger Fitting.jpg (101.13 KiB) Viewed 15252 times
Wood from the Pile.jpg (98.13 KiB) Viewed 15252 times
Chris
I like the walnut panel!
nuhobby
Just a little with a tool gloat
Post by nuhobby »
Not much time today, but one little lower-corner repair I'd been putting off was well-suited to my latest toy, the like-new used Lie Nielsen block plane I got.
[ATTACH]25065[/ATTACH]
[ATTACH]25066[/ATTACH]
Finger Splines.jpg (52.33 KiB) Viewed 15220 times
Trying New Plane.jpg (102.34 KiB) Viewed 15223 times
Chris
nuhobby
Chocolate & Peanut Butter?
Post by nuhobby »
The differently-aged pieces of the original oak haven't got as much closer together in staining as I'd hoped. I was a little dismayed at this. However, as I start to add pieces of brightwork, it is helping divert the eye from the contrasts.
[ATTACH]25115[/ATTACH]
Oak and Walnut.jpg (102.37 KiB) Viewed 15200 times
Chris
nuhobby wrote:The differently-aged pieces of the original oak haven't got as much closer together in staining as I'd hoped. I was a little dismayed at this. However, as I start to add pieces of brightwork, it is helping divert the eye from the contrasts.
So call it a 'Reese' !
