I do not know how small your skosh's are, but I use the thumb and finger method(one on each side) to barely move the fence. A mark on the table helps calibrate things.
BTW, disk sander works good on skoshes.
My skoshes are the Imperial ones:D MM skoshes are to fine for my work.
I'm making a sorta raised panel with the Dado set. A strip of contrasting wood is then inlaid (?) between the panel and the rails and stiles. Getting it all even around the perimeter involves skoshes.
I do use the mark on the table method.
I think I'll use the router table for the next set. That SS has the Jointech fence. Skoshes are easier to achieve.
