Loose Set Screw
beatnik
Post by beatnik »
Why not use these if yours are vibrating loose ?
http://www.mutualscrew.com/Alloy-Steel- ... 04469.html
1) Because they are cup point.:eek:
2) $$$$$$$$$$$$$$$$$$$$$$$:eek::eek::eek::eek::eek:
FWIW those are very similar to 'nylok' screws. Guess they are generic(nylon pellet) nowadays.:cool:
beatnik
Post by beatnik »
beatnik
Post by beatnik »
Just need to talk to a local bolt supplier and see if they will get a small quantity.
This would be a good solution but I was unable to find 5/16"-18x1/4" set screws with the nylon patch. Furthermore, that particular source appears to sell only in quantity lots. The smallest I found was 100 pieces per lot.
I found at McMaster-Carr that they do not have the 5/16"-18x1/4" with the patch either. I ordered some 3/8" long set screws with the patch just to experiment. Those should arrive tomorrow.
News at eleven.:)
beatnik
Post by beatnik »
Believe it or not, Amazon has them.
http://www.amazon.com/Black-Oxide-Alloy ... n+Patch%2C
beatnik wrote:Just need to talk to a local bolt supplier and see if they will get a small quantity.
A WHAT?
Fastenal maybe(BIG maybe).
One and only local hardware store will not do such an imprudent(to them) thing.
And all unnecessary IMHO.;) For a critical set and forget setscrew or an intentionally not tightened down setscrew(quill half dog) it makes sense. One frequently run in/out, nope.
beatnik
Post by beatnik »
5/16 is probably the closest you're going to get length wise.
beatnik wrote:5/16 is probably the closest you're going to get length wise.
So what is a reasonable thing to conclude?
Pears and strawberries are both fruits, but are not a substitute for each other. 5/16" is not a substitute for 1/4" when excess length is a potential problem.(even though this thread started with a question regarding 'extra' length)[or was that the 'other' one?]{Yep was the 'other' one!}
