12x20x8 high shop (240 sq. ft. heat with 18,000 btu direct vent
heater .. (propane) insulated concrete floor with pink 1 1/2
styarafoam insulation.. even when it is 20 below zero here in
Minnesota takes about one hour to make it 65 degrees. don't have to heat
the concrete every time ,..walls are 2x4, ceiling is 2x8 fiberglass insulation. floor is also easy on the legs. covered insulation with plyboard.
How do you heat your shop?
Re: How do you heat your shop?
- IMG_3993.JPG (69.08 KiB) Viewed 1603 times
ERLover
oldc6,
sounds cozy!!!! no need to go indoors
I think I need to SLAP you, Bra.keakap wrote:We heat our shops out here by turning off the air conditioning.
I used to live a few miles away from you.
(What is upper Kalihi, Mauka or Makai?)
steve
10 ER, stripped down.
