Refurbishing a MkV 510
John4337
Re: Refurbishing a MkV 510
Post by John4337 »
JPG wrote: Thu Sep 16, 2021 4:01 pm Well that explains the shiny(?) stuff on the edges of the motor belt.(migrated from idler pulley sheaves).
Insides also look like great progress will be attainable.
I think you gots a good un.
The white on the belt looks to be mold, and of course the belt is stiff as a board.
John4337
Post by John4337 »
Last one for today, lots of stuff going on in there..... what have I done....
Speed Control 1.jpg (405.75 KiB) Viewed 915 times
Speed Control 2.jpg (309.24 KiB) Viewed 915 times
Speed Control 3.jpg (385.2 KiB) Viewed 915 times
uh oh 1.jpg (405.94 KiB) Viewed 915 times
uh oh 2.jpg (369.37 KiB) Viewed 915 times
Majones1
Post by Majones1 »
Besides a lot of sawdust that needs to be cleaned out, all the parts look great to me. Wish my parts looked that good. That should clean up very well. The only thing missing from those photos is the motor. Looking forward to seeing how it has fared with all that sawdust build-up.
Marc Jones
You are DOING what NEEDS to be done!
Some of that mold rubbed of on to the sheave in the earlier pix.
John4337
Post by John4337 »
I've checked the bearings and they spin freely, no play and only a slight noise that you have to hold to your ear to hear. Question, can I immerse the drive sleeve in Evaporust with without harming the bearings?
drive sleeve.jpg (207.58 KiB) Viewed 885 times
John4337
Post by John4337 »
Majones1 wrote: Thu Sep 16, 2021 8:23 pm Besides a lot of sawdust that needs to be cleaned out, all the parts look great to me. Wish my parts looked that good. That should clean up very well. The only thing missing from those photos is the motor. Looking forward to seeing how it has fared with all that sawdust build-up.
Here's the motor
motor 1.jpg (383.26 KiB) Viewed 882 times
motor 2.jpg (308.33 KiB) Viewed 882 times
motor 3.jpg (268.9 KiB) Viewed 882 times
John4337
Post by John4337 »
Well, got the speed control cleaned up, but it was binding some, this looks to be the reason
speed control 4.jpg (195.82 KiB) Viewed 876 times
No need to 'evapoprust' the drive sleeve. rotary wire brushing will suffice followed by JPW.
Quadrant gear is typical wear, get a new one, but that one IS salvageable.
Check the pivot for sloppy fit.
Bearings are not supposed to 'spin freely'. They should have internal grease that slows the spinning.
I suggest the Bill Mayo fix for the quadrant support arms. I think someone who knows where it is will provide a link.
P.S. BEWARE the motor shaft tension spring!!!!
John4337
Post by John4337 »
Here's a video of the bearing
https://www.youtube.com/watch?v=VcOO1yuf20c
Dried out.
