Any brace that runs side to side in a canoe.
SS Panel Clamps
Re: SS Panel Clamps
Re: SS Panel Clamps
Re: SS Panel Clamps
Larry Hargrove
Rock Island, Ok
1957 Mark V 500 (350389)
1953 10ER
Another 10ER
Bandsaw 2012 Jointer 2012
Rock Island, Ok
1953 10ER
Another 10ER
Re: SS Panel Clamps
WHATSIT matter???
Re: SS Panel Clamps
That is the one you put across your shoulders behind your neck when you portage the canoe.
- 440px-Portage-prospector.jpg (139.64 KiB) Viewed 1395 times
Re: SS Panel Clamps
the shiny one is the portage yoke
Re: SS Panel Clamps
How far you can adjust in and still turn the crank, plus I looked at the original instructions
Last edited by larryhrockisland on Sun Jan 09, 2022 7:06 pm, edited 1 time in total.
Larry Hargrove
Rock Island, Ok
1953 10ER
Another 10ER
Rock Island, Ok
1953 10ER
Another 10ER
Re: SS Panel Clamps
Only on narrow glueups.larryhrockisland wrote: ↑Sun Jan 09, 2022 7:04 pmHow far you can adjust in and still turn the crank![]()
Re: SS Panel Clamps
Just add some additional unglued spacers of scrap outside of your panel and it isn't a problem.
- edflorence
Re: SS Panel Clamps
My Shopsmith panel clamps have seen a lot of use over the years and they do a great job. Occasionally, though, I have needed cauls longer than the panel clamps and the way I learned to make them is dead simple. No math, no measuring. Start with a 1x2 or 1x3 as long as you need and stand it on edge with a spacer under the center. The spacer is a scrap piece about 1/8 to 1/4 thick. With the spacer in place, clamp both ends down to a table or bench. Then set a scribe tool (which can be as simple as a pencil with a thickness of tape wrapped around it to get it to the right height) to match the gap between the table and the raised center of the caul and keeping the pencil on the bench top, scribe the caul from one end to the other. This makes a nice arc. Release the clamped ends and bandsaw and sand.
Idaho Panhandle
Idaho Panhandle
