Farmer, if that thing blew a fuse could we even find them now. I remember my first house in 67 and it had TWO of them to run the whole house and found out one of them had been wired around. Lucky it did not burn down before I rewired it. Knob and pole wiring in attic and saw dust insulation.
Those were the days.
Potpourri starting Jan 10, 2010
- wlhayesmfs
cocacola1012
A funny thing happened today. I plugged my drill in to drive a couple screws for a shelf project. I squeezed the trigger and nothing happened. So I told the LOML that the drill wasn't working. I went and bought another one, plugged it in (to the same outlet) and it didn't work.. Then I thought to check the breaker. It was tripped.. I kept the drill and put the old one away for now....
- kameljoe21
@ mickyd
Yes it will be the whole house and the basement as well
and the dog name is Sydney and shes an australian shepherd red merle
http://s853.photobucket.com/home/kameljoe21/allalbums
194X Spiegel 4.5" Jointer M600 NO460
1947 ShopSmith 10E S#9074
1957 McCulloch 55 Chainsaw
1955 Mall General Purpose Chainsaw
1952 Farmall H S#368935
1985 Honda 125M ATC
2006 Honda CRF 50 F
1978 Packard Drill Press M#120F-IND
195x Delta Table Saw S#AY4575
1997 Craftsman Chipper M#247797851
1982 Ariens Snow Blower M#ST504
194x Duro 30" Scroll Saw S#B07132PL
194x John Deere #5 Sickle Mower
19xx Antique Modified 3PT Hay Rake
1985 Honda 125M ATC
2006 Honda CRF 50 F
- robinson46176
wlhayesmfs wrote:Farmer, if that thing blew a fuse could we even find them now. I remember my first house in 67 and it had TWO of them to run the whole house and found out one of them had been wired around. Lucky it did not burn down before I rewired it. Knob and pole wiring in attic and saw dust insulation.
Actually fuses are pretty easy to find. Lots of drug stores carry them yet and so does Wally World. Mennards has a wide selection. There are also screw-in breakers that you can buy that screw right in the fuse socket to convert to push button breaker. I use one in one shop for an air compressor that sometimes blows a fuse if it has a hard time starting in cold weather.
In spite of what some folks think there is really nothing wrong with fuses other than the inconvenience and if your wiring is proper you rarely blow a fuse. I did actually have an insurance company turn me down because this house has fuses instead of breakers. I assume that their logic is that someone can easily put in a fuse that is way to high of an amperage for a given circuit or stick a penny in under it. I am pretty conservative about fusing. I try to use just as light of a fuse as possible, they are cheap.
This house is still fuses because when the service was heavily upgraded last my father did it (former electrician) and he was old school enough that he just preferred fuses over breakers. BTW, my old house (I had it built new) is all breakers and in the first couple of years I had three breakers fail and one did a scary amount of arcing when it went.
I have breakers in one barn but the other 4 are all fuses. Two are on another meter down the road about 600 feet. Here I have a pole about 30 feet from the house with a huge breaker box on it. The house has two underground feeds, each on their own breaker. The barns and a few sheds are on an overhead tri-plex feed on another big breaker. Each barn and shed then has its own fuse box or breaker box. There is also a separate feed in that big box to the well pit so that in case of fire we can kill power to the house and still have water to fight a fire with. I don't recall the breaker sizes in that big pole box. I have never had to reset one.
The fuse holders on the kiln are unique. They are a heavy socket held in place with EMT compression fittings.
