I think I would have drilled in from the back side and punched it out. Not sure if if would have worked. But in my head, it's a great idea. Looks like aluminum.mickyd wrote:Wanted……ER10 miter gage indicator….
I don’t feel I abused the heat from propane torch. I was evenly heating the piece and I felt the pliers that I was using start to close. I stopped immediately and looked at the piece and I could see where the pliers were digging in. Then I looked dead on at the face with the indicator button and saw where the top actually collapsed. I’m not sure if this piece is aluminum. Possibly white metal??
Anyway….disgusted!!
Restoration Progress On My 1952 ER10
Dave - Idaho
"Why do we drive on parkways and park on driveways?"
- mickyd
Based on part geometry, drilling from the backside would be tricky due to the angular surfaces of both the back end where you'd start the hole, and then drilling into the mounting holes 41°]only[/B] remembers failures.bucksaw wrote:I think I would have drilled in from the back side and punched it out. Not sure if if would have worked. But in my head, it's a great idea. Looks like aluminum.
Even though the attempt failed, I think it was a good logical starting point. Logical and failed in the same sentence????
Plan of action is.....drill through the center of the button and remainder of part with a small pilot hole being real cautious when I get to the mounting hole countersunk surface. I'll put a center punch dimple on the countersunk surface for the drill to locate on and continue through the part. Then come in through the backside with a slightly larger bit stopping when I get to the beginning of the button hole . Then insert an appropriate sized dowel pin to butt up against the back of the button and then smash the beejeezes out of in with a 12 lb sledgehammer (or a small ball peen hammer, which ever is closer). If all successful, JB Weld to hide the evidence, slap on a coat of primer, hammered paint, badda-bing, badda bang, Houston, we have a functional miter gage indicator!!
Sound like a plan??
Sunny San Diego
Sunny San Diego
mickyd wrote:And the ratio is............
Some of this, some of that. Oh and some lacquer thinner to boot! I just threw some together b4 an acquisition trip!
In fairness, the rust between the tube and the casting was not all that bad. The interesting part to me was how quickly it seeped through. Also how widespread it was when separation 'occurred'.
The thing is at this point you cant screw it up any worse by trying to fix it... GO FOR ITmickyd wrote:Based on part geometry, drilling from the backside would be tricky due to the angular surfaces of both the back end where you'd start the hole, and then drilling into the mounting holes 41° countersunk surface. Not saying impossible but definitely not a 'stage it up......plunge the drill in' operation especially for a semi-greenhorn such as myself. It looked like a broken drill bit waiting to happen, not to mention missing the general center area of the button in turn possible damaging the spring. It's probably above my machining skills. Had I done that, I would have REALLY kicked myself since 'the little guy' in the head kept saying "don't EVEN go there!!". The 'little guys' is like SWMBO....don't listen and pay the consequences.Even if you succeed, the 'little guy' only remembers failures.
Even though the attempt failed, I think it was a good logical starting point. Logical and failed in the same sentence????I'm OK with that. As I look at the piece today with lower blood pressure and calmer thoughts, I think it's still fixable.
Sound like a plan??
Sound like a plan??
I think so!
BTW an end mill would create a flat surface for the drill bit prior to drilling. Yah I know you have heard that before. This one does not have to be very large. Don't ya have any buddies in the machine shop bidness that might loan you one?
- shipwright
JPG40504 wrote:I think so!
I have some "buddies" that might do some work for me (free gratis) but I don't have any who will loan me tools.
That is a cardinal rule for me. I do not loan or borrow tools or weapons. I believe that one of the surest ways to loss a good friend is to loan him/her a tool (maybe money fits in there too).
- mickyd
Thanks for the compliments and words of encouragement. Your post about the brass replacement made me decide that if I can get this piece functional, I am going to polish it to a mirror finish like I did with my Greenie knobs / handles.nuhobby wrote:Mike,
Don't despair, dude! I just looked at the whole thread again, and you've done SO much.
I vote that you (eventually) make your own custom brass indicator. But start making sawdust now..... wood projects tend to have their own mistakes which require innovation along the way. It's good perspective on life, if you think about it.
Sunny San Diego
Sunny San Diego
mickyd wrote:Thanks for the compliments and words of encouragement. Your post about the brass replacement made me decide that if I can get this piece functional, I am going to polish it to a mirror finish like I did with my Greenie knobs / handles.Kinda like chrome plating a Pinto station wagon but sometimes, you just have an urge that needs to be satisfied, and this in now one of them!!
If he stays busy polishing it, he won't have to get either one of them all dirty making sawdust.
- mickyd
Sorry Paul (and Chris)....I can't.shipwright wrote:Mike
I'm with Chris. Stop working ON your machine and start working WITH your machine. Sawdust is better than Prozac and it doesn't make you homicidal. (all that often)
Paul M
When the sawdust starts to fly, which WILL BE SOON, it will fly with beauty and gusto. Hopefully, this summers Chris Craft restoration will not take me 100% away from other smaller type woodworking projects.
Sunny San Diego
Sunny San Diego
