Restoration Progress On My 1952 ER10
What color to paint my ER10? (post #216)
Poll ended at Sat Nov 21, 2009 12:35 pm
Other (post you answer)
18
50%
13
36%
5
14%
Total votes: 36
mickyd
Post by mickyd »
mickyd wrote:Based on part geometry, drilling from the backside would be tricky.......
Plan of action is.....drill through the center of the button and remainder of part with a small pilot hole being real cautious when I get to the mounting hole countersunk surface. I'll put a center punch dimple on the countersunk surface for the drill to locate on and continue through the part. Then come in through the backside with a slightly larger bit stopping when I get to the beginning of the button hole . Then insert an appropriate sized dowel pin to butt up against the back of the button and then smash the beejeezes out of in with a 12 lb sledgehammer (or a small ball peen hammer, which ever is closer). If all successful, JB Weld to hide the evidence, slap on a coat of primer, hammered paint, badda-bing, badda bang, Houston, we have a functional miter gage indicator!!
Sound like a plan??
Stroke of luck / twist of fate, whatever you want to call it. I'll call it a miracle that occurred while putting the center punch dimple on the indicator button. I use a spring loaded punch and in order to get a pronounced dimple, I usually click it 4 or 5 times. I did that and noticed that the button moved slightly inward. The post a few back showed where it was to start. I had previously rapped this thing MANY times both during and after the Kroil bath using a hard plastic mallet and couldn't get it to budge. Happened to me with a pickle jar one time&#8230]
[ATTACH]7482[/ATTACH]
Here's the setup I used to get the hole drilled into the button. The walnut pieces were a generous donation by our own mrcabinetmaker...thanks again Mark .
[ATTACH]7483[/ATTACH]
From there, the gears started rolling away from the original plan of drilling completely through the part and coming back in with the dowel to tunk the button out. Instead, with judaspre1982’s post still in my mind about tapping into the button and using a screw to pull it out, I instead opted for Ed in Tampa’s favorite tool……a #1 screw extractor.
[ATTACH]7484[/ATTACH]
Using a T-handle, I applied a torque that was less than the unpublished, undocumented, unknown maximum manufacturers recommended torque. I know it was less because the extractor didn’t snap. :p The button started to turn. It was real tight but it was turning. I was concerned about the extractor. I then pulled on and turned the extractor at the same time pair of vise grip and the button with the spring came out.
[ATTACH]7485[/ATTACH]
Next step was to get the thing looking like an indicator again. That will be another post.
Sunny San Diego
mickyd
Post by mickyd »
Here's the miter gage indicator restoration progress going from what I thought would be throw away to pretty respectable.
[ATTACH]7486[/ATTACH]
I first used a belt sander (upside down on my lap) with an 80 grit belt to reshape the piece the best I could. The belt cut very fast so I used caution.
[ATTACH]7487[/ATTACH]
Then went through progressive grit sanding using a finishing sander (again on my lap upside down) using 150, 220, 400, and finally 600 grit. From there, over to the 8" polisher with first spiral sewn wheel / black compound, then loose cotton / brown compound, and finally loose flannel / white compound. The Caswell Plating website is a great resource for all you need to know about polishing if your interested.
Here it is in all it's glory. Not too shabby considering what it looked like to begin with.
[ATTACH]7488[/ATTACH]
Sunny San Diego
nuhobby
Post by nuhobby »
Impressive! Congratulations!
If it didn't work out, it would have been a good homage piece for the old Star Trek "Doomsday Machine":
[ATTACH]7489[/ATTACH]
Chris
mickyd wrote:Here's the miter gage indicator restoration progress getting it from what I thought would be throw away to pretty respectable.
Then went through progress grit sanding using a finishing sander (again on my lap upside down) using 150, 220, 400, and finally 600 grit. From there, over to the 8" polisher with first spiral sewn wheel / black compound, then loose cotton / brown compound, and finally loose flannel / white compound. The Caswell Plating website is a great resource for all you need to know about polishing if your interested.
But But But . . . It is NOT 'Original':D
Good save!;)
mickyd
Post by mickyd »
[quote="JPG40504"]But But But . . . It is NOT 'Original':D
Good save!]
Slap some paint on it and driving by 60 mph you'd never know the difference. (ER's my custom beast, especially since it's painted pink and purple :p ...Greenie, now she's original)
Sunny San Diego
judaspre1982
Post by judaspre1982 »
DT aka Agent Orange is a POS
Liar Liar his wonky comb over is on fire
Last edited by judaspre1982 on Tue Jun 13, 2017 12:52 pm, edited 2 times in total.
bluekayak
Post by bluekayak »
Congratulations Mike. This was a day brightener, and I'm glad you were able to save it.
Jerry Floren
St. Peter, MN
etc92guy
Post by etc92guy »
Congrats - The condition of the M5 is envious. And your USING it. The lack of sawdust is immaterial.............;)
Craig
Hartland, WI
-Mark 5 "Greenie" S/N 342238, Manuf. mmm/mmm 1957, Acq. Oct. 2008, Joiner S/N M067266
-10 E/ER(?) S/N Unknown, Joiner 4E S/N 40051
mickyd
Post by mickyd »
Geez, while buttoning up the loose ends on the ER restoration today, listening to Pandora internet radio on my itouch, guess who came to mind??? :D
[ATTACH]7512[/ATTACH]
Sunny San Diego
judaspre1982
