I'm still new to finer woorworking, even though I'm not new to working with wood (15+years in tradeshow exhibit construction). I've got WW-ADD in a big way. Every new tool or thing I get my hands on is hot for a time, and I want to know everything about it, on and on... In the end, I really haven't done much or learned enough to do the things I want to do. However, I realize it's an issue and am starting to settle down and focus on some of the basics. I've got time (I hope), and I'll get to where I need to be eventually.saminmn wrote: I am so new to WW that last year I found myself needing to know/learn everything all at once. The slowness of my progress has been discouraging. I have accepted that I may never be really skilled at this, but in my own way and at my own speed I am learning. To dump a lot of money into an upgrade without getting a lot more productive with what I own right now would not make sense.
I see the Shopsmith and appreciate it for what it is: a good multitool that will cover many tasks. I'll use it for all it's worth, and probably stretch those uses to cover new and interesting processes that were never meant to be. However, I really doubt I'll go for the PP upgrade. I bought the Shopsmith to fill a couple of specific roles, mostly as a drill press and occasionally as a lathe and disc sander. I've got dedicated tools for almost everything else, and the PP upgrade really won't add to or stretch my abilities. If I outgrow the Shopsmith as a lathe, I'll find a dedicated unit that works for me. Same with the drill press.
Even if I do upgrade those other units, I'll keep it as a semi-portable work tool for the house. One can never have too many tools
