Rpm
dickg1
Post by dickg1 »
a1gutterman wrote:Merry Christmas Dick! Wood you believe it if I told you that I did knot want to take away from the message, so I spelled it "right" for a change? No? Oh well! I will strive to do better. :D
Of course I believe you Tim. Would you believe me if I said I actually saw a UFO hovering above the Millville NJ Police barracks? No, really I did, I did.
PS. You lie, I'll swear to it!
Dick
A Veteran-whether Active Duty, Retired, National Guard or Reserve-Is Someone Who, at One Point in Their Life, Signed a Blank Check Made Payable To "The United States of America", For An Amount of 'Up To and Including My Life'
charlese wrote:The difference between 19:33 and 5:33 PM is two hours. I had to solve my time posting issue by checking the Daylight Savings in the "User CP" (Control Panel).
Although you don't have a problem with DST while in AZ, You do have a problem with the proper time zone. You can edit your time zone in the User CP (Control Panel) The CP can be reached from the red line above, - location, farthest to the left.
P.S. Had to find that place again to make sure. It can be found in the user CP, under "Edit Options", Then you have to scroll down to the time and date options. I had to have Admin help me out with my time issue.
Oh I so wish I did not have a problem with DST while I am in Arizona. I routinely make telephone contact with people in Washington and California, in Montana and North Dakota, in Nebraska and Iowa, in Massachusetts and Mississippi.
Yeah, I'll call you at 2:00 PM on Saturday. BTW which time zone are you in? Are you on DST or no? I have this problem all the time. That coupled with the fact that I can not add or subtract 12 from 19 leaves me late (or early) or whatever all the time.
I think the whole world should convert to Zulu and we would not have this problem at all.
curiousgeorge
Post by curiousgeorge »
Dusty,
You can thank the railroads for the time zones we now have. Then of course, we can thank Ben Franklin for DST. :mad:
George
Ft. Worth, TX.
Go TCU Froggies
curiousgeorge wrote:Dusty,
There is absolutely no end to what one can learn on this forum. I didn't know the railroads had anything to do with out times zones and I didn't know Ben had anything to do with DST.
Here's two sites that disagree a little bit on the beginning of DST, but they are informative. Ain't knowledge wonderful?:rolleyes: http://en.wikipedia.org/wiki/Daylight_s ... ime#Origin
This one addresses DST in the U.S. http://aa.usno.navy.mil/faq/docs/daylight_time.php
bucksaw
Post by bucksaw »
paulmcohen wrote:There is a good reason, there are three three ways to connect to the headstock (one on the front and two on the back) and a speed reducer and speed increaser for the front. There is also a published design for adding a speed-reducer on the back for the bandsaw for cutting metal.
Putting all the different speeds on the dial would be confusing and inaccurate. Now why the chart is not a label on the machine is another question. My new machine came with the basic chart and it had a lot more information then just the RPM. The RPM chart was 5% of the chart in the bottom corner. The original chart listed every SPT and mode and many possible operations and suggested speeds in both RPM and letter.
Foe example under table saw they list speeds for Genneral Sawing, Heavy Ripping, Trim custs, dado and ider for Hardwood and softwood. For all the various sanders (disc, drum, belt, strip) they give speeds for both hardwood and softwood.
BTW: Does anyone know what "ider" is I am thinking it is a type for Molder.
Do you have a reference to the speed reducing for metal cutting?
Dave - Idaho
"Why do we drive on parkways and park on driveways?" :cool:
keakap
Post by keakap »
chiroindixon wrote:There is no need for my neighbor to declare "Mickey Mouse" when it could be simple.....
Doc
There's an answer to someone who would say that: "what a jerk".
The speed dial and various FREE charts provided by SS have been perfectly adequate for me, probably because I know that virtually every situation, almost every time the Mark V is turned on, is unique, and a speed dial label that covered every contingency would need to be about 5', 7-1/2" in diameter.
Rather unwieldy, that.
No matter what the configuration, be assured that there will always be someone who feels obligated to complain about it.
Cheers!
ronhollenbeck
Measuring Shopsmith RPM
Post by ronhollenbeck »
I measured the rpm of my Shopsmith using an optical tachometer. They are available from Tower Hobbies for a little under $30. They are intended to be used for model airplanes. They measure the speed at which the light changes from the prop passing in front of the optical sensor. I know it is accurate because when I point it at a lightbulb it says 3600 (60hertz X 60sec). To use it just mount the faceplate with a narrow stick screwed to it that extends a couple of inches beyond the edge of the faceplate. Then point the Shopsmith so that the tach will be pointed toward a window, turn off the lights, and begin taking readings while holding the tach a couple of inches from the spinning stick. My Shopsmith was purchased in about 1980 and has the original belts. The minimum RPM was 900 even and I stopped measuring at 5500. There was still a little more to go.
ronhollenbeck
Contact Tach
Here's a tachometer that would work great on the shopsmith.
http://www.harborfreight.com/digital-co ... 66400.html
