mark-b wrote:She runs again!
I put a new double pole switch in (thanks for the info. Ivan) Changed the polarity on the motor and put a 30' grounded cord on it (now I can plug it directly into an outlet instead of searching for an extension cord) The cord is grounded @ the switch and motor. Just have to finish up the little parts and then I will be moving on to Shopsmith #3, which is my 3rd ER. I am thinking of cutting the ways at about 30" and making a shortened Shopsmith that will be dedicated to the jigsaw, jointer, and turning bowls.
Mark
The motor condensor clears the headrest side by 1/4"
PLEASE do not cut the 10 e/r tubes!!!!!!!:eek: If you want to make a shorty out of a 10 e/r, get some mark5/v tubes and cut them! They have a thinner wall than the 10 e/r vintage. There are oodles of 5/v tubes, but fewer 10 e/r vintage. The thinner tubes are adequate for shorty/mini mods. Be aware that earlier Greenie/Goldie vintage(gilmer/3/4 motor) had 1 7/8" bench tubes(won't fit a 10 e/r. Newer goldies(1 1/8 hp motor/poly v) and gray model 5/v have 1 3/4" way and bench tubes. The bench tubes are 3/4" longer than the way tubes. Thought this info relevant to a 'used' tube search!
