Power Switch @ Home Depot
trainguytom wrote:I think that's the same switch I've used on mine & several others with no problems over time. Isn't the rating 10amp/220volt, 20amp/110volt? Aren't they inversely proportional?
The HP rating is what 'counts'.
Just a matter of contact durability.
billmayo
Post by billmayo »
grahamqt wrote: Hi
I don't know if you have the same switch as the my Mk V but I had a problem with the switch and was able to take it apart (the front unclips from the body of the switch) clean up the terminals amd reassemble. The switch now works perfectly
dusty wrote:When you say "clean up the switch" does that mean dust it out or burnish the contacts?
I am not going to try with a new switch but I believe the switches from Shopsmith cannot be taken apart and reassembled.
Some of the original Shopsmith Mark V switches can be disassembled and cleaned if you are careful not to break one or more of the switch tabs that holds the switch together. I find replacing the switch with a 1 1/2 HP rated switch always fixes the problem.
