New Look Forum
rjent
Re: New Look Forum
Post by rjent »
ryanbp01 wrote:I going to ask 2 stupid questions: What is prosilver? How do I make the adjustments?
BPR
Ryan, go to your user control panel, then choose the "board preferences" tab at the top. about 3/4 down there is "my board style" drop down menu. click the arrow and you have two choices:
Shopsmith1
and
Prosilver
:D
Re: New Look Forum
OK let's see what Forrestb encountered when posting his 1900 x 1080 screen shot.
1900 x 1080 jpg file
forrestb 4.jpg (640.04 KiB) Viewed 1502 times
We seem to have a moving 'limit'. :)
So let's try 1024 x 1024 tonight.
1024 x 1024
1024 x 1024
Different from last night! No size limit filter when uploading.
So try 1192 x 795
1192 x 975
1192 x 975
forrestb 5.jpg (406.48 KiB) Viewed 1502 times
Expanded cut off at about a width dependant upon the total width of your display. Seems to want 1/4 to 1/3 of the width for 'it's' stuff(prosilver)
joedw00
Enlarged images with font running off screen
Post by joedw00 »
Has anyone noticed that when the image is enlarged the font goes off the screen and you have to highlight the message and move
it to the right so you can read all of it. Unless you put the cursor in the
middle of the sentence and hit enter to move it down.
NORMAL IMAGE
NORMAL IMAGE
ENLARGED IMAGE
ENLARGED IMAGE
Re: Enlarged images with font running off screen
joedw00 wrote:Has anyone noticed that when the image is enlarged the font goes off the screen and you have to highlight the message and move
I think that is again dependent upon 'your' screen size.
"It" appears to respond to the user's screen(window) size and display things differently.
beeg
Post by beeg »
JPG wrote:I think that is again dependent upon 'your' screen size.
I think it more dependent on to large of a pic size. Like 1074 X 592.
Same problem, opposite 'view point'. ;)
A pix is too 'big' only if the display screen(window) is too 'small'. :rolleyes:
rcplaneguy
Re: New Look Forum
Post by rcplaneguy »
Definitely a more crude bb software. A step backward. Jmo of course. Scaling of images in 2014 should be automatic, simple, easy.
Re: New Look Forum
rcplaneguy wrote:Definitely a more crude bb software. A step backward. Jmo of course. Scaling of images in 2014 should be automatic, simple, easy.
I think the problems that you describe originate closer to home. The screen here is full, border to border, and the text wraps as would be expected. What size and brand monitor do you use? (rhetorical question)
algale
Re: New Look Forum
Post by algale »
For me it depends on whether I toggle between the two different viewing options (Shopsmith1 vs. Prosilver). In Shopsmith1 I am seeing the full photo but text wrap seems to be adversely affected. In Prosilver, the photo appears in a smaller window with scroll bars (until photo is clicked at which point it appears in a larger size) but the text wrap is working properly.
Re: New Look Forum
BuckeyeDennis wrote:
dusty wrote:Is the 'Who Is Online' function working as it did before. The number of members being reported as 'online' seems low.
I saw somewhere that only members who had been active within the preceding 5 minutes were counted. Simply being logged on apparently doesn't make the cut.
That is an interesting take. I'll be watching that. That approach would be much more valid; eliminating those who go to sleep, get distracted or pass out while logged in. I log in and seldom log out even when I turn my computer off.
