Your Shop Size?
- derekdarling
LEss than 100?
I have a storage shed, about 3' deep, by 15' wide, by 9'high, with double 3' doors in the middle of the lang side. My 10ER fits in one end, and the Mark V in the other. The bandsaw on its rollers fits in the middle. Other items live on shelves above. Working means rolling both machines out under the carport to form two 'walls', and the folding table for the third side. The bench grinder on its shelf is my sharpening station. Once I'm done, everything rolls away again and locks up. I polled 100Sq.Ft, only because there wasn't a '45 Sq. Ft. category.
Cheers!
Cheers!
Derek Darling
Surrey, B.C. Canada
10ERs, other stuff, you know.
Surrey, B.C. Canada
this is my shop 12x20 will upload pictures....... maybe???????[ATTACH]11079[/ATTACH]
[ATTACH]11080[/ATTACH]
[ATTACH]11081[/ATTACH]
[ATTACH]11082[/ATTACH]
[ATTACH]11083[/ATTACH]
- IMG_1795 (Medium).JPG (67.45 KiB) Viewed 2025 times
- IMG_1796 (Medium).JPG (69.29 KiB) Viewed 2024 times
- IMG_1797 (Medium).JPG (70.27 KiB) Viewed 2026 times
- IMG_1798 (Medium).JPG (75.64 KiB) Viewed 2027 times
- IMG_1799 (Medium).JPG (57.97 KiB) Viewed 2023 times
now, that i finally figured picture upload operation . shop is 12x20. old building that i moved in years back. on cement slab. after i retired i remodeled completely. 1 1/2 inch stryafoam, covered with 4x8 sheets.for floor. vapor barrier on floor, walls , ceiling. no more rusty tools....live in Minnesota so, have heat, and a/c. should be bigger but, it is what it is.... so, have to stay quite organized with stuff. everything is on wheels so, is very mobile..... another reason why the SHOPSMITH is a very fitting tool for the small shop... i can setup sawhorses and cut a 4x8 sheet quite easily.. lighting is four -eight foot two bulb fixtures.. sheetrock on ceiling and walls... painted eggshell white................
- robinson46176
oldc6 wrote:now, that i finally figured picture upload operation . shop is 12x20. old building that i moved in years back. on cement slab. after i retired i remodeled completely. 1 1/2 inch stryafoam, covered with 4x8 sheets.for floor. vapor barrier on floor, walls , ceiling. no more rusty tools....live in Minnesota so, have heat, and a/c. should be bigger but, it is what it is.... so, have to stay quite organized with stuff. everything is on wheels so, is very mobile..... another reason why the SHOPSMITH is a very fitting tool for the small shop... i can setup sawhorses and cut a 4x8 sheet quite easily.. lighting is four -eight foot two bulb fixtures.. sheetrock on ceiling and walls... painted eggshell white................
How revoltingly clean and organized...
Nice...
- easterngray
Curiosity killing me! What's in de box?
[ATTACH]11084[/ATTACH]
- c6 shop door box.jpg (9.34 KiB) Viewed 2022 times
J R in MO/TX
- Silver Member
I have to say 120 sq ft. I just purchase a used Mark 5, Have it sitting in the yard while I am building workshop shed.
A Grambrel roof unit 12' x 20'. 10 Ft or half is for shop and the other half will be a horse shelter.
SS learning expereince for me. Today I tweaked unit and cut all the rafter gussets or plates.
J R in MO/TX
J R in MO/TX
[ATTACH]11087[/ATTACH]
The stuff that goes with planer, and spindle sander. when machines are switched from top to bottom parts dont fall onto floor.............JPG40504 wrote:Curiosity killing me! What's in de box?
- IMG_1801 (Medium).JPG (63.31 KiB) Viewed 2006 times
