YouTube Videos featuring Shopsmiths
Re: YouTube Videos featuring Shopsmiths
reible wrote:I for one commented to the user and gave him the link to the PTWFE and invited him to join us here at the forums. I don't know if he has but he now knows about both. He did comment back so I know he knows.
For those who are still wondering about the tilt of the fence wonder no more. This link takes you to the section in question with pictures and verbiage:
http://www.shopsmith.com/academy/jointe ... #bevelcuts
This is how I learned to do it and I'm sure most manuals have the same method, pretty universal I would think. BTW the jointer we had at home had no guards, well if it ever did it did not when I knew it. It was a two function bench with small tilting table saw and jointer and a dual shaft motor, which belt you had on which end gave you the tool to use. I have never seen one other then the one we had.....
Anyway please keep the comments civil he may now be one of us here.
Yes, PTWFE shows a very clear picture (as does the jointer manual) of the most recommended tilt direction for the fence. The manual does however make comment about using the jointer with the fence tilted the other way (the way it was tilted when this accident occurred).
The manual reads: Warning: When the fence is tilted backwards work with extreme caution. Hold the stock so it won't slide out from under your hands. Use push blocks to move the stock.
Neither documents says it is wrong to tilt the fence as the OP did. Maybe not wise but not wrong.
I say again: The root cause was an inoperative guard and a secondary contributor was no use of push blocks. If the OP had taken the guard off and set it aside we might well not be talking about this at all. Trying to hold the guard in place set him up for what happened.
I commend him for posting this incident on uTube. Hopefully his doing so will save many others from his fate.
I do hope 'he' is amongst us so we can help him prevent a repeat performance with a different function.
Yes I was blunt with my previous post. I feel bluntness was preferable to glossing over.
Skizzity
Post by Skizzity »
https://youtu.be/sAvsV121E3w
Sent from my 2PZC5 using Tapatalk
skou
Post by skou »
OK, it's not Youtube, but it does rate.
Netflix, NCIS episode 10-5.
Tenth year, fifth episode.
Light, and the jigsaw.
No Speed changer, or the
elusive jointer. Even has the
mortising hold down,
Yes, worth every penny of the
$269.00!
But, so far, Jethro only uses it as
a "coffee" table. (Coffee being
single-malt Scotch!) Jethro and
Illya Kuryakin having a beverage.
https://www.netflix.com/watch/80048161? ... =200257859
steve
10 ER, stripped down.
rpd
Post by rpd »
Turning a bowl on a Shopsmith.
[youtube]https://www.youtube.com/watch?v=yS5J-LYJLVE[/youtube]
It seemed like the Mark5 was shifting around a lot, but I decided that, as he was sitting, he had probably left the wheels down to make it easy to change position.
skou
Post by skou »
Two videos. First shows them getting
a Shopsmith.
https://www.youtube.com/watch?v=2xilzP_Kcyk
Second video, organizing the storeroom.
https://www.youtube.com/watch?v=26sr2u2qL0Y
steve
rpd
Post by rpd »
rpd
Post by rpd »
rpd
Post by rpd »
rpd
Post by rpd »
A new video from Chris Neilan :)
[youtube]https://www.youtube.com/watch?v=E576inT7erA[/youtube]
