DLB wrote: ↑Wed Jun 14, 2023 9:13 amI agree with your comments on the thermal overload. The Gen 1 monitors what I believe is heatsink temperature of the control module and takes action (software) in case of overheat. The motor slows down but does not stop, which keeps the fan turning. You're supposed to stop using it. I don't know what to make of the addition of the old-school thermal overload monitoring something else, air or case temp. Is that in addition to the old system? If yes, does it trip at a lower threshold? I was surprised when I saw it on Jack's picture, from the words I thought they were adding it to the motor case. I presume that a Gen 2 either runs longer or shorter before overheating under like conditions. Maybe it's all in the manual...RFGuy wrote: ↑Tue Jun 13, 2023 7:30 pm Yeah, I kind of thought it looked like a thermal overload protector, but have only seen these on a few products. It looks resettable, but I was wondering how it worked, i.e. how can it be close enough to sense thermal temp of motor, but maybe the point is ambient rise inside the housing will set it off of the Gen 2 overheats? Referring to that device to the right of the fuse socket on the back of the headstock in the pic from Jack.
Phases - I think of this as naming convention. But I mostly worked on stuff with three phases and we referred to any 180 degree (or opposite amplitude) products as A', B', or C'. We called them phases. It is in the same category for me as direction of current flow, I learned electron flow in the service and had to re-learn it as conventional flow (aka hole flow) in college where amps flow in the opposite direction. As woodworkers, it is relevant that equipment labeled 230V single phase will work on household 240VAC (whether we call it 220, 230, or 240).
