I am not sure I would call it a bargain at that price, but. And he does not have the speed changer hooked up right.
http://milwaukee.craigslist.org/tls/5642227801.html
High $, yes but after all it has a complete 4E setup.ERLover wrote:I am not sure I would call it a bargain at that price, but. And he does not have the speed changer hooked up right.
So what would you do differently with the Speed Changer?
Reverse the motor pulley.JPG wrote:High $, yes but after all it has a complete 4E setup.ERLover wrote:I am not sure I would call it a bargain at that price, but. And he does not have the speed changer hooked up right.
I am not saying it not workable as he has it, but the MS sez it should be this way. I did not see the mounting for the jointer or if I remember right the extra pulley wheel for it, but I am not sure what to look for on that.JPG wrote:High $, yes but after all it has a complete 4E setup.ERLover wrote:I am not sure I would call it a bargain at that price, but. And he does not have the speed changer hooked up right.
http://www.vintagemachinery.org/pubs/338/2714.pdf
After relooking at the motor pulley, looks like it is 4 steps, and the far one to the left maybe for the jointer. With the 3 step in proper position.
I thought there was a hub to drive the jointer off the HS? Ya this is Skips for a jointer.
http://mkctools.com/sptdriveadapter.htm
Your turn John.
Set them straight.
I do not have the setup instructions.
FWIW, the pulleys are correct even without the fourth pulley.
Set them straight.
HS pulley is correct, I cant tell about the motor pulley, it does seem to have that extra 4" on the left side.JPG wrote:Your turn John.
Set them straight.
Johns in Sacramento,CA eating Cheese Cake. I do wait with baited breath. Then there was my recent purchase with that 2 step pulley, that was a learning experience for us
As most times JPG you are correct, on the motor pulley/s, there is the 3 step one, set in the correct position for the SC set up. Then an added 4.5 or 5" added to the left of that for what ever reason. I did a bit of photo work, my weak suite, but getting better at it.
Ah. You are correct. And I just got new glasses too.JPG wrote:Your turn John.
Set them straight.
