Power Swith PITA
Power Switch PITA
Hi Everyone
I have a 90's 500 with a 510 upgrade...
I KNOW that major maintenance hasnt been done in way too long so I tore into it today... cleaned out all the dust, oiled the sheaves, etc...
I need to replace the power switch and truly didnt think it would be as much of a PITA (yes, PAIN IN THE A$$) as I suspected.
The switch is the plastic version with the removable red "key". I was surprised to find that the switch had 3" pigtails on it. The switch still works, but... When I turn it off, I remove my finger and sometimes the SS jumps back to life, which scares the PEE out of me. So, I figured its time to replace it.
Anyhow - the switch was mfg by Lucerne USA - its a 16amp @ 125v DPST.
I have read virtually every post on the forum and have not found any reference to a replacement for this switch - only the standard metal toggles for Greenies and other 500's before SS went to this "safety switch"
Lucerne seems to be out of business... and I cant seem to locate a suitable replacement. I am not a fan of buying the switch from SS, because it is simply too expensive.
I really do not need the safety key feature, but I do want a switch that is rated high enough. I was considering this one:
http://www.grizzly.com/products/H8239
Does anyone have any experience with this particular switch? Will it fit in my casting (which I assume is a "C")?
Does anyone have a recommendation for a plain ole rocker switch that will fit the cutout and is the correct rating?
A BIG thank you...
Geo
A BIG thank you...
Geo
You can get a switch from Shopsmith. http://www.shopsmith.com/ownersite/itemfind.htm?item=522384&Submit=Find+Item
They now call it a service pack and it comes with extra wires and instructions. The key is no longer red - it is yellow and doesn't pull out. But it is a perfect fit for a C headstock.
BTW, Your switch probably had 4 terminals and one has broken off. In a standard Mark V , there is only 2 terminals used. One wire on top and the other on bottom of the same side. Nick showed us that if the switch becomes faulty, simply trade the wires to the other side, top and bottom. Worked for me!
Update - new switch installed
Hi everyone - I thought I would share an update. After much searching, I finally found a switch I am happy will do the job for a very long time. it is rated at 20amps at 125volts and 2hp. Better still, it had 1/4" terminals AND fit the cutout in my casting with no modifications!
My cost with my Grainger discount and local tax was $9.08.
Here is a link to the switch - The only unfortunate thing was that it isnt USA made...
http://www.grainger.com/Grainger/POWER- ... itch-2VLR2
Thanks,
Geo
SS switch by EagleTa2, on Flickr
Thanks,
Geo
eagleta2 wrote:Hi everyone - I thought I would share an update. After much searching, I finally found a switch I am happy will do the job for a very long time. it is rated at 20amps at 125volts and 2hp. Better still, it had 1/4" terminals AND fit the cutout in my casting with no modifications!
My cost with my Grainger discount and local tax was $9.08.![]()
http://www.grainger.com/Grainger/POWER-FIRST-Rocker-Switch-2VLR2
Thanks,
Geo
Good Choice!
From an electrical stand point any way.
Not as good from a safety point of view.
Looks a lot like the one on the power pro, nice fit. You could add on of the paddle switches inline with some magnets on the back for the safety aspect.eagleta2 wrote:Hi everyone - I thought I would share an update. After much searching, I finally found a switch I am happy will do the job for a very long time. it is rated at 20amps at 125volts and 2hp. Better still, it had 1/4" terminals AND fit the cutout in my casting with no modifications!
Thanks,
Geo
damagi AT gmail DOT com
This is the replacement "C" headstock switch I have used for many years. Only $6.39 per switch.
http://www.acehardwareoutlet.com/Produc ... KU=3135878
May not be in yer local Ace. They will order it usually. Save online shipping that way, but the wait is longer.billmayo wrote:This is the replacement "C" headstock switch I have used for many years. Only $6.39 per switch.
http://www.acehardwareoutlet.com/ProductDetails.aspx?SKU=3135878
Yes it is SPST. Just connect the white neutral wires and switch the linecord hot(black) and motor hot(blue?).
safety concern
Truth be told, I had thought of the safety concern of having a standard rocker switch in place of the locking switch that was originally there.
Then common sense took over. 8 feet from the SS is my miter saw that is plugged in all the time...and it could do more damage because there is NO safety cutout on that one. So why feel the need to protect from one machine when there's another one right behind it that isn't?
Finally... both of my boys (8 & 14) know that they will face the wrath of DAD if they dare to touch my equipment... they just know not to.
Maybe my head is in the sand, but I really believe that if you place too much trust in a safety device you stop paying attention and stop being careful.
Thanks
Geo
Thanks
Geo
