bearings (needle roller)
wa2crk
Post by wa2crk »
Does anyone know the number or the measurements or a source for the needle roller bearings for the upper band saw wheel? I had our community shop's bandsaw apart and forgot to look at the bearing numbers.
billmayo
Post by billmayo »
wa2crk wrote:Does anyone know the number or the measurements or a source for the needle roller bearings for the upper band saw wheel? I had our community shop's bandsaw apart and forgot to look at the bearing numbers.
Koyo Torrington B-88 Needle Roller Bearing, Full Complement Drawn Cup, Open, Inch, 1/2" ID, 11/16" OD, 1/2" Width. These are the ones I use. Available at http://www.amazon.com/Koyo-Torrington-C ... B006KT1CIE.
Be sure to check the size measurements are there are different size B88 bearings.
wa2crk
Post by wa2crk »
Thanks Bill.
billmayo wrote:Koyo Torrington B-88 Needle Roller Bearing, Full Complement Drawn Cup, Open, Inch, 1/2" ID, 11/16" OD, 1/2" Width. These are the ones I use. Available at http://www.amazon.com/Koyo-Torrington-Complement-Rotational-Capacity/dp/B006KT1CIE.
bill,
are you meaning to advise that this may not be the exact bearing that is in each of my bandsaws?
I did not want to pull bearings but maybe I must.
wa2crk
Post by wa2crk »
Dusty;
Which Bill?:D
Some bearings can vary in size. The 6205 series that are used in the drive shaft can have different sizes depending on manufacturer.
