What is the difference - Blades and Arbors
lightnin
Post by lightnin »
What is the difference between Mark V model 500 Blades and Arbors
and Mark 7 and Mark V models 505 510 and 520?
Since the table is adjustable they both fit on the same shaft couldn't you use them interchangeably?
Is the arbor diameter different?
Bruce
Ok Ok, I'm up to four now...
pennview
Post by pennview »
It's the length of the arbor that is different. Because the table size of the 505,510 and 520 are wider, arbors for these models are slightly longer. You can swap these among the models but you have to advance the quill or move the table slightly to compensate. I'm not sure how the blade guards will line up however if you swap arbors.
Art in Western Pennsylvania
The Mark 5, Mark VII and Mark V(500) are the same. 505...520 are longer. Also the design has changed from the older versions.(different nut, shape)
SDSSmith
Post by SDSSmith »
lightnin wrote:What is the difference between Mark V model 500 Blades and Arbors
The 500 arbor will not work with the Mark 7 and Model 510/520 lower saw guards....too short.....period. You can use the 500 arbors on the newer machines with out the guards.
Rob in San Diego
lightnin
Post by lightnin »
OOPS.... I guess I shoulda asked that question sooner...
Actually I just noticed there was a difference when ordering blades.
I have accumulated seven model 500 arbors now.
I just looked at them all look the same length.
Bruce
tgamel
Post by tgamel »
JPG40504 wrote:The Mark 5, Mark VII and Mark V(500) are the same. 505...520 are longer. Also the design has changed from the older versions.(different nut, shape)
Good to know, have been wanting to purchase some extra saw arbors for my Mark V, just assumed if it was 5/8" they would all work no matter the machine, As of now, I only have one blade (the original combo blade that came with the SS).
Now I have noticed that there are two sizes of arbors the 5/8" and the 1 1/4". Never new that there were two sizes, as I have never bought any extra blades for my craftsman table saw. Is there a real need to have have both arbor sizes, or do most brands/types offer blades that have center holes of both sizes? I visit to the local Lowe's and Home Depot looks like 5/8" is the standard there. What has your experience been?
Todd (Canton, TX)
1962 Magna Corporation Mark V Goldie (Serial #379277); 1983 Shopsmith Mark V Model 500 (Serial #165199, w/bandsaw & joiner), Shopsmith 20" Scroll saw w/stand (Serial #030191), and Shopsmith DC3300 dust collection system. Taking my time, learning all I can and making a big mess!
tgamel wrote:Good to know, have been wanting to purchase some extra saw arbors for my Mark V, just assumed if it was 5/8" they would all work no matter the machine, As of now, I only have one blade (the original combo blade that came with the SS).
The 1 1/4 arbor hole is sorta unique to SS for the 9" and 10" blades. That arbor size is more prevalent with larger sized blades.
IMHO the larger arbor size is an advantage(more grip area and blades tend to wobble less).
That is not to say 5/8" blades are 'inadequate'.
Yes most(if not all) blades at you know where will be 5/8".
Shopsmith blades are (almost all) 1 1/4".
lightnin
Post by lightnin »
Hey Todd, I got extra 1¼" arbors for the model 500, I'll send you a couple for the postage cost.
PM me if you want em' ... It'll be the end of the month before I can get to the Post office when there open though....
Because I'm workin' a lot of overtime to buy a PowerPro and double tilt.
Bruce
tgamel
Post by tgamel »
lightnin wrote:Hey Todd, I got extra 1¼" arbors for the model 500, I'll send you a couple for the postage cost.
Sent ya a PM...
Todd (Canton, TX)
tgamel
Post by tgamel »
JPG40504 wrote:The 1 1/4 arbor hole is sorta unique to SS for the 9" and 10" blades. That arbor size is more prevalent with larger sized blades.
Thanks for the info, like I mentioned the only blade I have so far is a SS combo blade. Good to know that the 1/14" is SS specific as I want to purchase so additional blades in the near future. So far however the SS blade is adequate for my needs. Looks like it would be good to have a couple of each on hand. The only accessory that did not come with my SS when I bought it was the arbor wrench, but I am guessing a good crescent wrench would work adequately.
Todd (Canton, TX)
