Help in finding staples
I have a staple gun that uses 1/4 (10mm) x 1/4 or 5/16 staples. The only ones I can find are 10mm x 3/8 which are too long. Any one know where I can find the shorter ones. The gun is a Swingline (no longer made and they don't make the staples either).
Not certain if they carry what you are looking for, but Fastenal has had some staples I needed (stapling networking wire) that no one else could find.db5 wrote:I have a staple gun that uses 1/4 (10mm) x 1/4 or 5/16 staples. The only ones I can find are 10mm x 3/8 which are too long. Any one know where I can find the shorter ones. The gun is a Swingline (no longer made and they don't make the staples either).
If there is a store nearby I would go there in person. They needed to look in a catalog to find mine since they were not immediately found in the computer system. Had to buy 10,000 but when you need it you need it.
Hope that helps.
- cincinnati
I had an old Swingline and found staples at a SEARS Hardware. this was in the last year or two. Not sure of the size I found but they did fit the gun. I think the staples were for a Craftsman gun (air ???) and labeled as such. Do a search on Sears web site and see if they offer what you need.db5 wrote:I have a staple gun that uses 1/4 (10mm) x 1/4 or 5/16 staples. The only ones I can find are 10mm x 3/8 which are too long. Any one know where I can find the shorter ones. The gun is a Swingline (no longer made and they don't make the staples either).
"Prove to all the world Metal rules the land"
-Judas Priest, Heavy Duty.
www.wirewerkes.com
Hiding in a Joshua Tree.
The shortest leg on those is 3/8 (which is what Home Depot, Lowes and Ace have. Too long for my stapler. I'll check Sears tomorrow. If I find some I'll buy a few boxes. I think those with 1/4 or 5/16 legs are not being produced.wiredone wrote:http://www.mcmaster.com/?orderview=new#staples-for-powered-staplers/=iz5q79
See if any of these fit the bill.
10mm or 1/4 width works. 3/8 on the width is too wide and on the length is just 1/16 too long. Went to sears and the width was off by 1 cm, just enough to jam the gun. So, unlike condoms, it seems that with staples, one size doesn't fit all.greitz wrote:Maybe I'm confused- 10 mm staple width is close to 3/8", not 1/4".
McMaster's staple group J, in 3/8" staple width, lists both 1/4" and 5/16" leg lengths.
Am I missing something?
Gary
The only size that will work is 1/4 width and 1/4 or 5/16 length. Tough to find.
Thanks for the help. I know one of you out there knows the answer.
- curiousgeorge
Hi,
Any chance you have the number of the stapler?
I have a box of staples that are too narrow for my "standard" stapler, they say they are for a Swingline 10401 (plus a list of other staplers). Below is a shot of the difference.
[ATTACH]18283[/ATTACH]
The standard one looks to be about a 1/2" wide (outside to outside) and the smaller one looks more like 3/8" inside to inside.
None of the boxes I have talk about the width of the staple, only what model it fits and the length of the leg.
- DSCF3549sc.jpg (38.03 KiB) Viewed 4398 times
