The instructions that come with the Ring Master have a very complicated way to calculate the cutting angle when they could have just included a table.
I used Excel to calculate these so it anyone wants the template just send me private mail. There is a 1/2 degree discrepancy from the manual at 3/8" that I can't explain.
Wood
Thickness - Angle
3/8 - 40.0
7/16 - 35.5
1/2 - 32.0
9/16 - 29.0
5/8 - 26.5
11/16 - 24.5
3/4 - 22.5
13/16 - 21.0
7/8 - 19.5
Ring Master Cutting Angles
Paul Cohen
Beaverton, OR
Beaverton, OR
Paul, Excellent Point. Sometimes inventors/engineers/manufacturers ignore the more practical applications of their products such as considering - "What would I want if I were to purchase, then try to use the product."
Could the 1/2 degree difference be due to rounding error? Maybe only trial and error will tell!
To be as kind as possible to the mindless hack who pasted together Ringmaster’s dismal excuse for an Owner’s Manual, it really does suck dead toads. The business that you have pointed out concerning angles is just one of the many, many boats this clueless cretin missed.
Not so with the tool. Drew and I have been exploring the Ringmaster for these last few weeks, getting ready for the January 12 Sawdust Session, and we’ve found that it is delightfully versatile and capable. I fully expected to find that it was a moderately useful gizmo the capacity of which could be demonstrated in 15 to 20 minutes. Not so. Drew and I are now considering that it will take 3 or 4 sessions just to explain the major uses of the Ringmaster, and we can already see possibilities for more.
Those two things being established – the tool is great; the manual is horse puckey – let me say one more thing. There is no reason in the world why the user should be restricted to using a single angle for a given thickness of stock. In fact, if you reject this premise, begin exploring what you can do with a range of angles, and navigate this new territory using a little trigonometry, the possibilities begin to multiply quickly.
This coming weekend, I’m going to address how to create bowls with straight sides from a single piece of wood. Select the thickness of your stock (up to 1”) and the slope of the bowl wall (up to 45 degrees), then calculate the “ring spacing” needed to achieve it. You can also figure the wall thickness, if you want. The illustration below hints at the process. If you plane your stock to 3/4” thick and want to create a bowl with walls sloped at 30 degrees (not the suggested 22-1/2 degrees), cut rings every 7/16”. (3/4 x tan30 = 7/16) They will match up perfectly.
[ATTACH]775[/ATTACH]
By the way, Drew and I have also developed an Excel calculator for the mathematically challenged who would rather not deal with sines, cosines, and tangents. Think of it as a GPS for exploring Ringmasterland.
With all good wishes,
- Stacking_Ringss.jpg (28.13 KiB) Viewed 25426 times
Nick Engler
http://www.workshopcompanion.com
I just found that the Shopsmith version of the Ring Master came with a CD with a new manual. I almost threw out the box without noticing it. The CD has a lot of information but not a simple and clear as what Nick posted. There is also a commercial application called ProtoShaper I am not sure how it is different than the Excel sheets Nick has created.
Paul Cohen
Beaverton, OR
Beaverton, OR
Re: Ring Master Cutting Angles
I have a used ringmaster and I sure could use your excel program. How can I get a copy?
Jim
Jim
. .twobachs wrote:I have a used ringmaster and I sure could use your excel program. How can I get a copy?
Jim
Welcome aboard, but I suspect you won't get an answer, This thread is 11 years old. Also, I just checked Paul's profile and it has been almost two years since he was last active on this forum.
Bummer. Thanks for getting back to me.
I should have read the thread a bit more.bach939 wrote:Bummer. Thanks for getting back to me.
The spreadsheet was actually mentioned by Nick.
It is part of Sawdust Session 14. The link is below. you have to scroll down the window on the right to get to the spreadsheet.
http://www.shopsmithacademy.com/SS_Arch ... _Bowls.htm
