Small roll pin
mrhart
Small roll pin
Post by mrhart »
There is a small roll pin in my parts box as I'm putting things back together. Its hard to see it on the diagram, I'm trying to remember where it goes. I remmeber there was some mistake on a thread a while back of someone thinking it was an allen head screw. I remember it just taps out...:confused:
R Hart
mrhart wrote:There is a small roll pin in my parts box as I'm putting things back together. Its hard to see it on the diagram, I'm trying to remember where it goes. I remmeber there was some mistake on a thread a while back of someone thinking it was an allen head screw. I remember it just taps out...:confused:
Some dimensions might help. OD, length.
mrhart
Post by mrhart »
1 inch long, maybe 1/8 diameter.
R Hart
What have you taken apart?
Table Height Control Handle maybe? No. That one is not 1" long.
SDSSmith
Post by SDSSmith »
How about the pin that goes in the shaft that holds the base arm in the base (right side of the frame)? If you had more than one, I would suggest looking at your casters.
Rob in San Diego
SDSSmith wrote:How about the pin that goes in the shaft that holds the base arm in the base (right side of the frame)? If you had more than one, I would suggest looking at your casters.
Ditto!!!!!!!!!
mrhart
Post by mrhart »
I think its the pin that goes through the threaded rod and handle on the carrage lock.
There has been gremlins on my work bench.
R Hart
mrhart wrote:I think its the pin that goes through the threaded rod and handle on the carrage lock.
That one would be smaller (< 1").
