Ripping black rubber from Band Saw wheels
randyrls
Post by randyrls »
Well; The urethane tires arrived and I started removing the black rubber tires from the band saw wheels. The black tires are badly worn and crowned so bad a narrow blade rides about 1/2" in front of the backed bearing. I will be aligning the upper wheel next.
Tried Lacquer thinner but started to get woosy so I clamped the wheel in my woodworkers vise and had at with a utility knife. First one is done with only a few minor nicks and no blood shed.
On the positive side, I learned several new curse words in languages I didn't know I knew. :D :D :D
Randy S.
Commit Random Kindness and Senseless Acts of Beauty.
maggeorge
Post by maggeorge »
:cool: Unfortunate circumstances can sometimes bring out the best in you ...
damagi
Post by damagi »
[quote="randyrls"]Well]
I mostly clamped and used a flat screwdriver...annoying but worked
damagi AT gmail DOT com
heathicus
Post by heathicus »
The easiest way to get the black rubber tires off is to put on a blade and tension it, then connect the headstock with the speed set pretty fast. Turn it on, and before you can say "oh, crap!" the black rubber tires will be off and in several pieces. :eek:
Don't ask me how I know this works... :o :o
Heath
Central Louisiana
bosox
Post by bosox »
Installing and removing of the rubber tires were not that hard anymore . :)
videobear
Post by videobear »
heathicus wrote:The easiest way to get the black rubber tires off is to put on a blade and tension it, then connect the headstock with the speed set pretty fast. Turn it on, and before you can say "oh, crap!" the black rubber tires will be off and in several pieces. :eek:
Oh, you use this method too?
I used mineral spirits and a wire wheel in a hand drill to get off the residue.
Regards,
Doug
Shopsmith Mark V ->Mark 7, bandsaw, jointer, planer, belt sander
bosox
Post by bosox »
I found a site that might help you in replacing your used tires. Try to read this informative blog here
steamfab
Post by steamfab »
I put solvent on the edge of the rubber tire and let it settle for a while. This really takes time.
A test of patience for me.
