Nathaniel's Gun Case
Gene Howe
Post by Gene Howe »
After one coat of my super secret, highly technical wiping varnish formula. :D
Nothing fancy. Just a utilitarian case to carry guns from home to the range and back.
Mesquite veneer over BB, maple, and walnut.
[ATTACH]19330[/ATTACH]
Inside. The wife made a tool bag that will lay in the space next to the bullet block. She's going to cover the foam cushioning in the lid and lower body of the case with the same denim like material.
[ATTACH]19331[/ATTACH]
Normally, I like to french fit these but, he trades guns and buys different ones quite often. So, a one size fits all solution seemed the best. However, the bullet block is glued in and the holes are sized for .45.
A few more coats of Watco and marine varnish, and the hardware can be installed.
[ATTACH]19332[/ATTACH]
Thanks for looking.
case 2.jpg (54.07 KiB) Viewed 1010 times
case inside.jpg (49.77 KiB) Viewed 1017 times
case hdwr.jpg (53.8 KiB) Viewed 1009 times
Gene
holsgo
Post by holsgo »
Now thats inspiring. Been thinking about a 357 with a 5in barrel. Might even do a lever action 357 or a 308. Haven't decided. Great case to carry.
judaspre1982
Post by judaspre1982 »
Gene Howe
Post by Gene Howe »
Thanks guys. I think it will serve the purpose.
Gene
