Urethan Tires: Anyone Like Them?
algale
Post by algale »
It is time to replace my bandsaw tires. They are cracked and have taken a set and my 1/4 inch blade no longer make contact with the autotrack bearing.
I am looking for feedback on urethane versus rubber. Has anyone who has made the switch been satisfied with urethane?
Thanks,
Al
heathicus
Post by heathicus »
I didn't have my bandsaw long before a SNAFU required that I replace my aging rubber tires (hint: don't turn the machine off on a high speed setting, connect it to the bandsaw, then turn it back on!). So I don't have much experience to compare to, but the urethane seems to be serving me quite well. I chose urethane because I just didn't want to mess with glue to install the rubber tires.
The urethane tires weren't as hard to install as I had feared. Just follow the instructions and have a couple clamps on hand.
Another thing you might want to try is some "belt conditioner" on the tires. My old rubber tires were dry and cracked and I think the belt conditioner did soften them up a bit and increase their useful life. No telling how long they would have lasted had I not destroyed them by not paying attention to what I was doing.
Heath
Central Louisiana
algale
Post by algale »
heathicus wrote:I didn't have my bandsaw long before a SNAFU required that I replace my aging rubber tires (hint: don't turn the machine off on a high speed setting, connect it to the bandsaw, then turn it back on!). So I don't have much experience to compare to, but the urethane seems to be serving me quite well. I chose urethane because I just didn't want to mess with glue to install the rubber tires.
I will look into belt conditioner. It's gotta be less expensive than new tires and if it works it will save time and money. Any brand/source of belt conditioner you could recommend?
heathicus
Post by heathicus »
No specific recommendation. I know mine is in a red can. :)
Heath
Central Louisiana
ryanbp01
Post by ryanbp01 »
I went ahead and replaced my rubber tires three years ago and they are great!! They are very resistent to temperature changes. If I would buy a new bandsaw, I'd replace the rubber tires with the urethane tires, I like them that much.
BPR
heathicus
Post by heathicus »
algale wrote:I will look into belt conditioner. It's gotta be less expensive than new tires and if it works it will save time and money. Any brand/source of belt conditioner you could recommend?
Pretty sure this is what I have:
But, I say go ahead and replace them with the urethane tires if you can. I don't think you'll be disappointed.
Heath
Central Louisiana
beeg
Post by beeg »
Yep I read that link. Especially "Also, they come with a crown which allows the blade to track better on it. ".
beeg wrote:Yep I read that link. Especially "Also, they come with a crown which allows the blade to track better on it. ".
I assume we are discussing the urethane tires used on a Shopsmith. If that is the case, the "crown comment" confuses me. I don't think I want a crown. :confused:
The Shopsmith does not work well with a crown - does it?
dusty wrote:I assume we are discussing the urethane tires used on a Shopsmith. If that is the case, the "crown comment" confuses me. I don't think I want a crown. :confused:
Consider the 'source'!
Not the first time for irrelevant 'advice' from there.;)
bosox
Post by bosox »
[/B]
If the wheel has crown.??. I don't need to think of that ..
