Adjustable pen mill
kenbu
Adjustable pen mill
Post by kenbu »
Just started turning pens -- and it's fun! Started with Slimlines and got a 7mm pen mill for trimming blanks, which worked fine. But, on kits with larger tubes, the mill was a sloppy fit inside the tube. I see mill kits with multiple shafts available, but they are a bit pricey, and aren't sized for every tube diameter. I tried sanding them, but the blanks aren't always (OK, almost never) square and true with the center hole.
It occurred to me that I already own a very large collection of shafts with precisely graduated diameters: my drill bit index! I could find one to slip snugly inside any tube I'm likely to encounter and chuck it in my M2 tailstock chuck. All I had to do is reverse the direction of the pen mill cutter and mount it in my headstock chuck. I just slide the blank into the spinning cutter until I see the shiny brass ring. Cheap, simple, accurate and easy.
Here is my 7mm pen mill ready to trim a Push Click blank sliding on a 21/64 bit.
Ken
kenbu wrote:Just started turning pens -- and it's fun! Started with Slimlines and got a 7mm pen mill for trimming blanks, which worked fine. But, on kits with larger tubes, the mill was a sloppy fit inside the tube. I see mill kits with multiple shafts available, but they are a bit pricey, and aren't sized for every tube diameter. I tried sanding them, but the blanks aren't always (OK, almost never) square and true with the center hole.
Ken
There be transfer punches that would work better(think drill bit with no flutes - i.e. different sized straight 'rods').
http://www.harborfreight.com/28-piece-transfer-punch-set-3577.html
RobertTaylor
pen mill
Post by RobertTaylor »
if you turn your drill bit around you will have good results. myself I just "turn" different sized wood blanks to fit inside the larger tubes as I use the disk sander to square up the ends. as your pen mill gets dull you will destroy a few blanks and ask yourself/others if there is a better way.
kenbu
Post by kenbu »
JPG40504 wrote:There be transfer punches that would work better(think drill bit with no flutes - i.e. different sized straight 'rods').
Hmmm. Would these also be useful in pen disassembly?
kenbu wrote:Hmmm. Would these also be useful in pen disassembly?
Not having ever 'disassembled' one, I ain't gotta clue!:o
Culprit
Post by Culprit »
Yes. Transfer punches are one of the preferred disassembly tools.
1955 Greenie, modified to be reversible
terrydowning
Post by terrydowning »
+1 on the punches.
+1 on Bob's approach with the disc sander. I find raising the tailstock slightly provides additional surface area for on the sanding and keeps the paper from wearing out i one spot.
Terry
Public Photos of Projects
http://sdrv.ms/MaXNLX
