Serial number lookup
How do I look up the age of my machine based on the serial number?
- chiroindixon
number check
Go to the Shopsmith.com site and open the owners section. Next on a top bar, open the Mark V section. A selection list will drop down. Select serial numbers and you should get chart of serial numbers and the year built. Easy....
- wurlitzerwilly
Use this link:danbean wrote:How do I look up the age of my machine based on the serial number?
http://www.shopsmith.com/ownersite/serialnumber.htm
Cut and paste. Straight in - no searching!
Regards,
Alan.
www.theatreorgans.co.uk
www.virtualtheatreorgans.com
Admin: UKShopsmiths Group
Theatre Pipe Organ Builder
ShopSmith V520 + Power Pro
Alan.
Okay, so my serial number is 204330. From the list, I could have a 1985 or 1986 model. I thinks SS told me once it was a 1985, but there is no way to know from this chart. Now they use the date of manufacture, so I guess they make at most one per day. That makes it a lot easier if you have a newer machine.
It is at the shopsmith site:
http://www.shopsmith.com/ownersite/faq/markv.htm
down at the bottom of the page.
