Evaporust question
Evaporust question
I was wondering if evaporust is ok to use on nylon locknuts. I was disassembling a big tube tunnel slide to clean and would like to derust the 100 or so screws, washers and nuts. Thanks for any input!
- BuckeyeDennis
I've never evaporusted nylon, but I'm 99% sure it would be fine. Evaporust is amazing gently stuff, it doesn't even harm paint. And nylon has good resistance to most chemicals. But to be safe, you can simply test it on one and see what happens.jayp413 wrote:I was wondering if evaporust is ok to use on nylon locknuts. I was disassembling a big tube tunnel slide to clean and would like to derust the 100 or so screws, washers and nuts. Thanks for any input!
I've never used Evaporust. Where do you buy it? I have a sump pump that needs a cleaning.
WmZiggy
williamz@aol.com
williamz@aol.com
Nylon resin is pretty much resistant to everything at room temperature. There are a few compounds that will dissolve it with heat, but most of those would show up on an MSDS sheet and Evaporust has nothing to report there. The only other concern is long-term exposure to strong acids or bases, but one again I think Evaporust is fairly close to pH neutral as its not classified as a skin or eye irritant.jayp413 wrote:I was wondering if evaporust is ok to use on nylon locknuts. I was disassembling a big tube tunnel slide to clean and would like to derust the 100 or so screws, washers and nuts. Thanks for any input!
But to CYA, don't leave it in a closed up, hot shed for a week and you should be fine on the nylon.
- apexsunguitars
Chemical Resistance Guide
Here's a link to the chemical compatability website that I use:
http://www.coleparmer.com/Chemical-Resistance
Two each Shopsmith Model 500, 505, 510s. Sawsmith Model 500003. Most of the SPT goodies aside from the compressor and the Planer.
Lowes recently closed out evaporust at all stores near me.
In addition to HF, autozone. HF is cheaper and has those 20% off coupons.
Many Farm and Ranch supply stores carry it. Bought mine at 'Tractor Supply'. Do not know if they have any of those in North Dakota though.WmZiggy wrote:I've never used Evaporust. Where do you buy it? I have a sump pump that needs a cleaning.
Todd
Todd (Canton, TX)
1962 Magna Corporation Mark V Goldie (Serial #379277); 1983 Shopsmith Mark V Model 500 (Serial #165199, w/bandsaw & joiner), Shopsmith 20" Scroll saw w/stand (Serial #030191), and Shopsmith DC3300 dust collection system. Taking my time, learning all I can and making a big mess!
