Interesting 10ER Modifications
fredsheldon
Post by fredsheldon »
Here are some clever 10ER modifications.
http://daytona.craigslist.org/tls/4067720123.html
Fred Sheldon
The Woodlands, Tx
algale
Post by algale »
Those are interesting. Do you think the support table is drilled to allow the homemade air cleaner to pull saw dust down through it? Also, not clever enough to justify the asking price!
alisfair
to much
Post by alisfair »
I have a restored 10er with orignal chisels in original box, speed changer, shaper attachment and jig saw attachment, and manuels , plus owners manuel, and many parts accessories. I would be happy to get 400. If he sells his I should raise my price lol
joedw00
Post by joedw00 »
Looks like it is well taken care of, I like the big table,but it is a little pricey.
Joe
Being a VETERAN is an honor
Being a GRANDPA is priceless
Casters and a speed reducer would be nice 'additions' to help justify the $.
And a jointer head for the shaper fence, but since the 4E jointer is there, that head is likely long lost.
That box looks like a vac hose connection, but it is unclear where it is used. It might be under the right end of the table extension. I do not think the table is drilled, but it may be 'grooved'.
Interesting miter gauge extensions(2) and a lathe tool rest 'alteration'.
$/2 or less be reasonable.
Yes it appears to be well kept! Gorgeous way tubes!!!
SDSSmith
Post by SDSSmith »
Hopefully, there is a 'box' that is not shown that goes with it. It is missing a couple key components to make the 4E jointer 'go'.
Rob in San Diego
SDSSmith wrote:Hopefully, there is a 'box' that is not shown that goes with it. It is missing a couple key components to make the 4E jointer 'go'.
OK, I'll bite, what is missing?
He has a pulley on the jointer shaft.
He has a std 3 groove pulley, but inside that is a larger pulley. I guess he removes the 3 groove pulley, moves the larger one out to connect a belt to the 4E pulley.
Not 'typical', but would likely work.
peterm
Post by peterm »
Interesting mods:) .................So future viewers will know what we are looking at:
[ATTACH]23070[/ATTACH]
Peter
SDSSmith
Post by SDSSmith »
JPG40504 wrote:OK, I'll bite, what is missing?
I guess missing and mis-installed. The jointer drive belt is missing and the motor pulleys are bass-akward. The 5" pulley which I overlooked goes outboard. Otherwise you will probably experience and interference fit (pun intended).
Rob in San Diego
jere
Post by jere »
That looks like a blacksmiths furnace blower re-purposed, neat idea. I see those come up on Craigslist for next to nothing. I think I am going to use that table extension idea on my non ER SS.
