what to do with motor
I took a 1/3 hp 1725 rpm CW only rotation off a swamp cooler.
is there anything I can do with this motor?
the beal system require CCW---so that is out.
TIA
TIA
- joshh
If you can get to the windings you can probably make it reversible. What brand is it?
- 1986 Mark V 500 Mini
- 1985 Mark V 510 with reversible motor, bandsaw, jointer, and double-tilt.
I offer quality motor reversal, rebuilding, and rewiring. Contact me at HarbourTools@live.com
Simpler 'conversion' from CCW to CW.
Remove the end bells(caps).
Reverse them and the armature.
This will not work if it is a capacitor start motor with a start switch on one end.
Being a smaller hp motor, it may not be a capacitor start motor.
Which means they did not provide external wires and a method for electrically reversing it.farley wrote:it's a Emerson.
Says on the motor "motor is non-reversible"
My suggestion was mechanical.]type[/U] motor is it?
- timsturnings
If you could post a couple of pictures of your motor it may help with assistance.
Tim.
Tim.
Seven days without turning makes one weak.
1952 Shopsmith 10er(restored)with Speedchanger,1952 Craftsman 10" table saw,Jet 1014 lathe(VS),HF VS 95607 Lathe,Craftsman Drill Press,55 Gal. Tornado Dust Collection System,Shop Wide Overhead Vac piping,WC slow-speed grinder,Wolverine sharp. system,Grizzly GO580 14" Bandsaw,Rikon Disk/Belt sander,HF Pressure Pot, JB 7 CFM Vac pump,TurnTex Stabilizing Chamber. (My 16' X 20' shop is full to the gills)
We already know about capacitor start motors.farley wrote:by type I don't know what you mean.
this probably shows my skill sets off
There are also capacitor run motors.
There are shaded pole motors(no capacitors)(low starting torque, commonly used for fan motors).
There are inductive start/run motors also(sorta the inverse of capacitor start motors)(they usually have start relays).
Does it have either a capacitor or relay, or both or neither?
