After you choose "all files and folders" you must also choose "Local Hard Drive (C: )" or where ever else you want to look.osx-addict wrote:Make sure you're searching the ENTIRE computer.. Since it sounds like you're using Windoze, you can do that using the Start-Menu and then select "search".. Once the window with the dog comes up (I'm using XP), select "all files and folders" and go from there.
Stealth PDF Files
- a1gutterman
Tim
