Mark VII
Re: Mark VII
I am sorry that I had you confused. Thanks, Larry McCord
Re: Mark VII
lwmccord wrote:I am sorry that I had you confused. Thanks, Larry McCord
That's OK! A lot of folks think I am confused!
Re: Mark VII
You have made some terrific finds. You mentioned that you had hyst overpaid for a plastic cam, and now have a metal one. Would you sell the plastic?
Re: Mark VII
NOW I am confused! If it was me, where?????lwmccord wrote:You have made some terrific finds. You mentioned that you had hyst overpaid for a plastic cam, and now have a metal one. Would you sell the plastic?
Re: Mark VII
Does anyone know where I can get one of those metal speed controls for my Mark VII?
Re: Mark VII
Another member had some made. AIUI he does not have any more. They were $$$$$$$$$$$$$$$$$$$$$$$$$$$$.stdavis wrote:Does anyone know where I can get one of those metal speed controls for my Mark VII?
Another member has 'printed' some with a 3d printer.
If he chooses, he may add to this thread.
Re: Mark VII
Thanks JPG. I have a 1956 Mark V owned previously by uncles from each side of my family and also a 1966 Mark VII purchased new by my dad in 1966 when the 3/4 horse motor in his Mark V went out in the middle of building our house. I've been using the Mark VII for 50 years now. Rebuilt it myself (new bearings and all) about 20 years ago. Been through three of the plastic speed controls. Forced to using mostly the Mark V these days due to the current plastic mess in the Mark VII. I was a sheet metal worker for 35 years. I guess I'll just have to hunker down and fabricate a speed control here myself. Thanks again!!! Happy shopsmith sawdust times to all!!!
Re: Mark VII
I sincerely hope that sufficient lubrication of the cam follower bearing would have prevented the three cams from getting damaged.stdavis wrote:Thanks JPG. I have a 1956 Mark V owned previously by uncles from each side of my family and also a 1966 Mark VII purchased new by my dad in 1966 when the 3/4 horse motor in his Mark V went out in the middle of building our house. I've been using the Mark VII for 50 years now. Rebuilt it myself (new bearings and all) about 20 years ago. Been through three of the plastic speed controls. Forced to using mostly the Mark V these days due to the current plastic mess in the Mark VII. I was a sheet metal worker for 35 years. I guess I'll just have to hunker down and fabricate a speed control here myself. Thanks again!!! Happy shopsmith sawdust times to all!!!
Did you use it for extended periods of time?(run continuously between power down).
Re: Mark VII
JPG. The Mark VII has done a lot of work in its lifetime. I am one who is kind to my machines. I've always kept the shafts for the sliding pulley shives properly lubricated ( quite anal about that actually). I always turn the machine off after completing each operation. And yes I do know to lower to the lowest speed prior to shut down. This avoids a lot of stress on the machine during restarting. The bearing that holds the yoke that contacts the speed cam has been a major contributor to the heat problem. I purchase high quality bearings but have had some failure rate in that position. Thanks for your interest!!! :-)
Re: Mark VII
My 'interest' comes from my intent to use a restored Mark VII in the near future. It will become the work horse as older SS are also refurbished.
I am particularly concerned re the cam as I will be using a 3D printed one.
I am curious if the bearing heating was at higher speeds(low rise portion of the cam). Did the 'button' melt through the cam surface there?
