A Slow Boat To Nowhere
algale
Post by algale »
It has been a looong time since I started this project last fall. After getting the strongback and stations cut and the strips milled I got stopped by a series of things that I won't bother folks with. But I have picked it up again and started laying strips. It is starting to look vaguely canoe like![ATTACH]25789[/ATTACH]
rjent
Post by rjent »
algale wrote:It has been a looong time since I started this project last fall. After getting the strongback and stations cut and the strips milled I got stopped by a series of things that I won't bother folks with. But I have picked it up again and started laying strips. It is starting to look vaguely canoe like![ATTACH]25789[/ATTACH]
Looks like a great start! Making a beautiful wood canoe is one thing I have always wanted to do. I built a ski boat with twin 4 cly mercury's on it back in the 60's when I was in HS. Worked great and had a blast with her until we ran her aground and punched a hole in her hull. You are only a teenager once ... thank God!
Dick
1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
algale
Post by algale »
A little more progress has been made on the slow boat.
[ATTACH]25874[/ATTACH]
edflorence
Post by edflorence »
Looking good! Please do post pictures when you get to the "filling in the football" part of the hull. That is the most interesting part of the project to me.
Idaho Panhandle
shipwright
Post by shipwright »
Looking good.
Time isn't important.
Enjoying time is important.
It looks to me like you are enjoying the build so have at it. :-)
algale
Post by algale »
Ed: I'll take some photos of the football when I get there. I know that's the most difficult part to strip.
Paul: Yup, it is fun and a little addictive to finally be building my first boat. Massive time absorber, though, for such a little canoe (16' long by 36" in the beam). I can't imagine how long it must take to build something bigger.
algale wrote:Ed: I'll take some photos of the football when I get there. I know that's the most difficult part to strip.
Bigger boats, wider strips.;)
algale
It's Not Fair
Post by algale »
I'm having problems with the slow boat. At certain forms if I drive the strip flush to the form I am getting a dip at the form and the strip no longer makes a fair line. This does not happen on both sides of any given form and it is a problem on one side towards the bow on the other side one towards the stern. To minimize the problem I am letting the strip float about 1/8th of an inch above the form in some spots. I guess I will just soldier on and try to sand out as much of the dip/hump as possible when I fair the hull. My concern is that the strips will not meet along the center line towards the bow and stern.
Here's a sample.
[ATTACH]25891[/ATTACH]
beatnik
Post by beatnik »
Could you use band clamps or tie down straps to help hold those in place ?
algale
Post by algale »
beatnik wrote:Could you use band clamps or tie down straps to help hold those in place ?
That may be part of the solution. I have cranked the strips down tighter to the forms and while this creates a "bulge" between the forms, if I push down with a finger midway between the forms, the "bulge" evens out into a more fair line. When I lay the next strip I will see if a tie down fixes the problem.
