PowerPro Rattle on Startup
I have a brief, less than a second, low rattle when I start my power pro above 2000 RPM. It's more noticeable, i.e. a bit louder, under load like with a saw blade on the spindle. Otherwise it is purrs smooth as silk. Is this typical? Is there an adjustment I need to make? I haven't talked to ShopSmith yet. I thought I'd asks the experts here first. Thanks
rickm808 wrote:I have a brief, less than a second, low rattle when I start my power pro above 2000 RPM. It's more noticeable, i.e. a bit louder, under load like with a saw blade on the spindle. Otherwise it is purrs smooth as silk. Is this typical? Is there an adjustment I need to make? I haven't talked to ShopSmith yet. I thought I'd asks the experts here first. Thanks
Yes, typical!
Re: PowerPro Rattle on Startup
On my machine the rumble does not go away. As I increase the speed it gets louder and higher pitched. Is this normal?
I have had it 3 years but used very little until the few months - maybe 30 hours total until now. I don't recall it sounding like this when it was new.
All advice appreciated.
Sounds like belts need to be adjusted to me. I readjusted mine recently and eliminated 90% of the rumble.
Jack
Jack
A while back I found a new rattle and traced it to a loose set screw on the new quick-index quill handle. With the set screw slightly loose it would rattle as it was powering up. If I put my hand on the lever it wouldn't vibrate, without my hand on it it would. Checked and found the set screw loose so I fixed it and there went the rattle.
Then just the other day I head a new rattle. That turned out to be the fact I had taken the upper blade guard off to do some rabbits and for got to tighten the wing nut....... a couple of twists and that rattle went away.
Moral of the story is look for something loose in addition to other possibilities. It could as was mentioned be loose belts, or needs to have the belts re-balanced. We have also heard of loose pulley due to set screw coming loose on I think it was the motor????
Thanks all. I will check these out over the next few days and let you know how it works out.
As I said back in September of 2014 (above) the rattle is typical. After reading, communicating on this forum, I assume the "rattle" (or slight banging noise) when starting from a dead stop to 3450 RPM was caused by the motor self correcting itself while rapidly gaining speed.
Today, after edging a few boards on the jointer, I noticed there is no such "rattle" on starting from a dead stop to 3450 RPM.
Then I put on a saw blade to cut lengths from these boards - and left the jointer coupled. So the future startups turned both the jointer and the saw blade. THERE WERE NO SUCH NOISES!! only the winding up whir of the machine.
