Thickness planner vs MDF?
- ChrisNeilan
I need a piece of MDF that is slightly less than 1/2 inch thick. I have a supply that is just over. Can MDF be run through a thickness planner? Definitely would use a dust collecter and my Trend Air Shield!
Chris Neilan
- rjent
I see you have a belt sander. You might try that. I would imagine that a planer is going to do a number on the material.
How much do you need to thin?
Dick
Dick
Dick
1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
1951 jigsaw X 2
- ChrisNeilan
rjent wrote:I see you have a belt sander. You might try that. I would imagine that a planer is going to do a number on the material.
Dick
I need to thin it less than 1/8 inch. I'm making a support panel for my Dubby Sled and it has to be dead flat. I could order a piece for $$$, but I already have a scrap piece. Kinda one of those metric vs standard things I think.
Chris Neilan
- rjent
Put some 80 grit in the belt sander and I think you could take your 1/8th inch off easily. I ran a belt sander 35 years ago when I worked with NASA and have just gotten this SS belt sander up and running. I am impressed. as for accuracy, just take your time and keep measuring with a straight edge. I am afraid that the planer will chip out chunksChrisNeilan wrote:I need to thin it less than 1/8 inch. I'm making a support panel for my Dubby Sled and it has to be dead flat. I could order a piece for $$$, but I already have a scrap piece. Kinda one of those metric vs standard things I think.
JMHO
Dick
Dick
1951 jigsaw X 2
1951 jigsaw X 2
rjent wrote:I would imagine that a planer is going to do a number on the material.
Dick
I wood think that the MDF wood do a number on the blades.
As beeg has said, the MDF will dull the blades much more quickly than real wood but the planer does a fine job on MDF. Just do very, very shallow cuts.
The dust will be horrendous. If you do not already have the capability, I suggest you acquire the capability to sharpener your own planer (and jointer) blades.
- ChrisNeilan
Thanks guys. I think I'll give it a try. Nothing to lose except a piece of scrap MDF.
Dusty, thanks for the advice. I've had the planner (Dewalt) for three years and have not yet sharpened the blades. It's cutting fine but could probably use a touch up by now. I do have a Tormek T-7 with the planner blade jig and I've used it on my Shopsmith jointer. Works great! I'll sharpen after... I bet it's a pain in the calf getting these blades in and out:eek:
Chris Neilan
Only is you leave them in place for an extraordinary long period of time. I sharpen mine frequently enough that they do not seat enough to be a pain.ChrisNeilan wrote:Thanks guys. I think I'll give it a try. Nothing to lose except a piece of scrap MDF.
On the other hand, you do not want them to come out too easily.
ChrisNeilan wrote:I need a piece of MDF that is slightly less than 1/2 inch thick. I have a supply that is just over. Can MDF be run through a thickness planner? Definitely would use a dust collecter and my Trend Air Shield!
In the past I have built several painted projects using MDF that required both the jointer and planer. It has been my experience that the surface of MDF is more dense than the middle when you plane off the surface the exposed surface is not as hard & smooth as the original surface. I would be interested in your results. If you decide to use the planer to surface the MDF.
Glenn
