Plexiglass Problem
- idcook
Plexiglass Problem
Working on a project using frosted plexiglass and having a devil of a time trying to drill holes in the stuff without the bit getting stuck at one point or another.
Anybody here know how this can be done?
Thank for your help.
I use plunge router bits, not drill bits. They do make regular drill bits for plastic also. I have heard of running a std bit in reverse but never tried it.
I also drill polycarbonate, not plexiglass. They do have different cutting/drilling characteristics.
http://www.eplastics.com/Plexiglass_Lexan_Plastic_Drill_Bits/DB-375?gclid=CjwKEAjw8O2hBRDKur2lseLW6C8SJAC-r1J3meweMTFTmOOmAsrzL9K_zxp2IxcMnqzOss8xVVzj7RoCPG7w_wcB
Slow RPMs.
Slow feed.
Well secured.
Keep it all cool and steady.
I think (Sharp)brad point bits work better.
Slow feed.
Well secured.
- idcook
Sorry folks; I found myself asleep before checking here. Thanks for the answers and info supplied so far.ddub wrote:JPG,
I could see where those would work well.
idcook, how thick of plexiglass are you drilling?
ddub, I was hoping I hadn't failed to include the thickness; alas!
They're a tad shy of one inch thick.
I found a bunch of the stuff at a local junkyard. Been buying slabs, roughly 25" x 35", at five bucks each for the past few months. I'll likely wind up buying all he has.
He called it plexiglass so I say the same whenever he and I do a deal. However, the stuff cuts pretty easily on a tablesaw. Producing consistent, snowy chips but begins to melt after two minutes or so. It doesn't stick to the blade but builds up behind it.
It also drills pretty easily, but when I stop it immediately cools and hardends onto the bit.
I'll run some tests for speed before drilling the final pieces.
idcook wrote:Sorry folks] it immediately cools and hardends onto the bit.[/color]
SLOW it down!!!!!!!!
