PowerPro upgrade question, quill and upper drive pulley
shopsmithpaul
Post by shopsmithpaul »
Can anyone explain why it is necessary to install a new quill and upper drive pulley with the PowerPro. I have new bearings with little time on them and they are in great shape. I work in the machinery maintenance field and also did headstock rebuilds for SS many years ago. I will admit I don't know everything. Do they use different bearings or something. I talked with SS and did not get a suitable answer and no way to buy PowerPro without the added expense of those parts. I understand the need as far as making sure worn out parts are replaced. Thanks for your input.
Paul
510, bandsaw, jointer, belt sander, jointmatic
nuhobby
Re: PowerPro upgrade question, quill and upper drive pulley
Post by nuhobby »
I think you know as much as anyone. I've heard from rebuilders that the upper drive-sleeve bearings on an old machine are the first to wear out, I think. They (SS) may also want to ensure all PowerPros have a solid-aluminum piece rather than the 2-piece (steel shaft) upper sleeve structures used for earlier models. Furthermore they (SS) may wish to get rid of any odd-size pulleys such as have been used on 50Hertz induction models.
I don't know and I have done no specific research but I believe that the higher RPM capability of the PowerPro necessitates that those bearings all be validated. Said another way, I believe that Shopsmith may just be verifying that the bearings are capable of those new performance levels.
larryhrockisland
Post by larryhrockisland »
Somewhere in the Powerpro upgrade pages it states these items must be installed for warranty and to keep yours as spare. Forgive the lack of a link, me and my IPhone don't work well searching and pasting.
Larry Hargrove
Rock Island, Ok
1957 Mark V 500 (350389)
1953 10ER
Another 10ER
Bandsaw 2012 Jointer 2012
billmayo
Post by billmayo »
The Power Pro headstock can operate at almost twice the RPMs of the regular Mark V headstock. The old bearings would most likely fail at the higher Power Pro RPMs. I find I have to replace the drive sleeve bearings on almost all headstocks when rebuilding them. I use higher quality bearings than the original for a longer life span.
You may want to save the removed parts and assemble another Mark V headstock. I find the MINI Shopsmith setup does not take up that much room and is excellent for powering the SPTs. This helps reduce setup time for projects. I have any extra headstock available with all the parts needed to complete another headstock using the removed parts.
shopsmithpaul
Thanks for the input. That is pretty much what I was thinking. I was hoping to find out if the bearings were better grade. I am trying to do upgrade with less cost, but does not appear to be an option.
Thanks, Paul
larryhrockisland
I found the web page http://www.shopsmith.com/shopsmithpower ... rchase.htm
In the DIY option.
Larry Hargrove
Rock Island, Ok
1953 10ER
Another 10ER
I think Dusty nailed it!
It makes no sense to me re keeping the old parts as spares for the PP. Now if you rarely run above 5200, then it would.
