Manual for old lathe duplicator
algale
Post by algale »
Anybody got a copy of the manual for the older lathe duplicator, p/n 555209?
Thanks in advance
Al
Re: Manual for old lathe duplicator
I rediscovered a pdf on an older computer.
The Forum is gagging on the pages 2-17 file.
I will attempt to split it and upload the pieces tomorrow.
MANUAL COVERS.pdf
(1.05 MiB) Downloaded 859 times
MANUAL 18-31.pdf
(1.01 MiB) Downloaded 657 times
MANUAL STEADYREST.pdf
(294.58 KiB) Downloaded 631 times
Easier to do than I thought, so:
Well it gags on the smaller files also????(2-9 and 10-17).
TRY AGAIN, 2-17
Pages from MANUAL 2-9S.pdf
(1018.97 KiB) Downloaded 569 times
Pages from MANUAL 9-17S.pdf
(962.83 KiB) Downloaded 993 times
sECOND IS 10-17
G'NIT!
algale
Post by algale »
Thanks!
delong94
Post by delong94 »
Thank you for uploading JPG.
delong94
Cutter Heads
Post by delong94 »
Will any other cutter heads fit on the duplicator base? I know Easy Wood Tools makes some for their chisels (http://www.easywoodtools.com/).
Re: Cutter Heads
delong94 wrote:Will any other cutter heads fit on the duplicator base? I know Easy Wood Tools makes some for their chisels (http://www.easywoodtools.com/).
Perhaps, but you would also need the plastic pattern 'follower'.
