Accidents can always find a place to happen but they often occur in an area that is cluttered and in disarray. I hope that most of you don't know what that is like. There was a time when I could have said "{Not my shop. It is always neat and orderly".
No more. I have been working on the RV and the shop has become just a place to cut something and then back to the RV. My oldest commented that "This just does not look like your shop. Do you need help getting organized"?
No. I don't need help but I do need to stop working in that mess and make it a place to "Make Sawdust Safely" once again.
A SAFE SHOP is a TIDY SHOP
- Hazardous Shop 001 (Large).jpg (996.14 KiB) Viewed 2042 times
- ChrisNeilan
Re: A SAFE SHOP is a TIDY SHOP
I agree... Mine looks very much the same nowadays, right down to the Folgers can. Big plans this weekend to fix all that!
Unfortunately my shop always seems to look like this. I typically give it a thorough clean up once or twice a year but in no time it is in total disarray.
Translation ?dusty wrote: . . . I have been working on the RV and the shop has become just a place to cut something and then back to the RV.
I have been too busy getting work done to have time to be a neat freak.
I know you are not serious. That sort of rationalization just gets us in trouble. I have begun the recovery process.JPG wrote:Translation ?dusty wrote: . . . I have been working on the RV and the shop has become just a place to cut something and then back to the RV.
I have been too busy getting work done to have time to be a neat freak.![]()
I spent this morning just gathering up tools and putting them back where they belong, oiling tools that need oil (pin nailer, etc and trashing the obvious trash. The area is still in turmoil but I have eliminated most of the trip hazard (unused extension cords, cords plugged in that need not be, etc).
Cut myself with a band saw blade that had been hung over the headstock of the Shortly. This goes back to when we were discussingthe resaw blade with Forrest. I took an old blade (declared DOA) off of the one machine and installed my Shopsmith 1/2" blade for test comparisons.. There hung the old blade until now.
I see that there are a couple wrenches missing off my tool board. Strange the things you notice in pictures that are disregarded otherwise.
- robinson46176
Dusty you have no grasp of the whole concept of mess...
My woodshop isn't too bad, just not together enough yet but my farm shop is a whole other world...
Waaaaaay too much of a catch-all. I hope to change that as soon as it warms back into the 30's and 40's before too long. These below zero nights are leaving too much cold behind to even try to have any safe heat in there now.
A son-in-law just gave me a big stack of decent used plywood from a job and between that and what I will be able to saw on the Woodmizer in a few weeks I will be able to change the whole picture in that shop. Adding here that I am feeling far better than I have for most of the last year and ready to get started...
About that aluminum Z vise on your bench... Do you always use it with the clamp screws up on top of the bench? I don't think I ever have but I can see where it might be an advantage on some benches with limited room to turn them below.
Did anyone see the TV show about the place that makes thousands and thousands of pins for timber frame buildings? They were working in about 4" to 6" of shavings on the floor and almost never cleaned them up. They said that it was nice and soft...
Matthias Wandel said he always had several inches of sawdust in his old shop, and that he missed it because it was soft.robinson46176 wrote:..... Did anyone see the TV show about the place that makes thousands and thousands of pins for timber frame buildings? They were working in about 4" to 6" of shavings on the floor and almost never cleaned them up. They said that it was nice and soft........
I'll bet it is soft, but..
1. I am constantly dropping nuts, bolt, washer, etc on the floor.
2. That's a lot of fire starter.
No, that is not a typical application for me. I moved it here to do something, I don't even remember what, and have not mopved it back. The zvse has several different configurable positions, however and they all seem to be functional.robinson46176 wrote:Dusty you have no grasp of the whole concept of mess...![]()
My woodshop isn't too bad, just not together enough yet but my farm shop is a whole other world...![]()
