Wood handle ferrules
robinson46176
Post by robinson46176 »
I have only done this about once and I don't have a picture. A lot of us have made new tool handles especially for chisels or files etc. Over the many years I have turned handles and looked for something to make a ferrule if the old one was gone. Lots of times I would cut off a piece of larger copper tubing and turn the handle to accept it as snug as I could make it. I have messed up one or two driving one on that was too tight.
The last one I turned to fit a 3/4 copper PEX crimp sleeve and made it a slip fit. Then I got out my PEX crimp tool and crimped it in place. Very easy. The trouble is my crimp tool was $100+ so that is kind of pricy for just repairing a few handles. :rolleyes: Now though they have bolt tighten crimpers that are about $20 which brings it to a more reasonable level for non plumbers. Here is a crappy picture of one on Amazon.
http://www.amazon.com/Nibco-Px02555-Blo ... B007764Q3C
If you are equipped for a little metal working it would be easy to drill through a steel plate about .50" thick and then saw the plate in half through the center of the hole and use a heavy vise to squeeze the ring in place. It doesn't have to be perfect, it won't leak... :D
garys
Re: Wood handle ferrules
Post by garys »
I use short sections of copper plumbing pipe. Then, get the wood cut so the pipe fits on and epoxy the pipe onto the wood for a tight fit that never lets go.
