What is "hook & loop disk"?
I read a reference to "hook and loop disk" from "berry 11/21/06". As I am interested in new tools and procedures I would like to know what it is. Appreciate any info. Thanks!
- Ed in Tampa
Tomtomlaw wrote:I read a reference to "hook and loop disk" from "berry 11/21/06". As I am interested in new tools and procedures I would like to know what it is. Appreciate any info. Thanks!
Hook and Loop is basically velco type fastener. You have probably seen it where you can press two things together and they stick until you forceably pull them apart.
One side is kind of a fuzzy material and the other is tiny plastic j type hooks.
The little hooks get stuck in the fuzzy material and hold until you apply enough force to straighten the hook out.
It works real well to hold sanding disks to sanders since you can chance the paper and reuse it. Also the material has a little give so there is a little less heat and a slight slight rounding effect.
Hope I explained it well enough
Hook & loop.
Thanks Ed. My only excuse is I hadn't yet had my morning cup of coffee while reading the forum. It's still a great web site!
Tom L
Tom L
