Drum sanders
Bruce
Drum sanders
Post by Bruce »
Does anyone know what the difference is between the 6 inch drum sander and the multi-sand drum sander? They appear to be the same size, but the part numbers are different.
rpd
Re: Drum sanders
Post by rpd »
Bruce wrote:Does anyone know what the difference is between the 6 inch drum sander and the multi-sand drum sander? They appear to be the same size, but the part numbers are different.
Shopsmith Multi-Sand Drum Sanding
The drum is the same, the difference is what else comes with it.
Shopsmith 2-1/4" x 6" Sanding Drum - Includes: Drum Sander and One Medium Grit Sanding Sleeve.
Complete Multi-Sand Starter Package Includes: 6" x 2-1/4" Drum Sander • 1 Each Coarse, Medium and Fine 2" Sanding Sleeves • Vacuum Attachment • Vacuum Extender and • Table Insert (for 500 or 505, 510 and 520)
Bruce
Re: Drum sanders
Post by Bruce »
That makes sense. I should have caught that in the description. Thanks.
