ao smith motor repair
I am new to this forum.I have recently acquired a Shopsmith brownie with the AO Smith 1 1/8 hp motor.At startup motor hums so I, m thinking capacitor.I have ordered a new one but would still like to take motor apart to inspect the winding.Does anyone know the disassembly procedure.Your help will be greatly appreciated.Disc42
Re: ao smith motor repair
There are excellent posts on the Forum, search for AO Smith 1 & 1/8 HP Motor Guide - Forward / Reverse, Bearings, Wiring, etc. dated 04-29-2013 by JOSHH. I am sure this should answer most of your questions.disc42 wrote:I am new to this forum.I have recently acquired a Shopsmith brownie with the AO Smith 1 1/8 hp motor.At startup motor hums so I, m thinking capacitor.I have ordered a new one but would still like to take motor apart to inspect the winding.Does anyone know the disassembly procedure.Your help will be greatly appreciated.Disc42
Thanks I,ll check it out.
Start capacitor unlikely culprit.
Start Switch far more likely!
Can you buy new ones.If so where.
disc42 wrote:Can you buy new ones.If so where.
One 'fixes' the one one has. Likely a small piece of crud(non-conductive) between the points.
Alternative purchase, motor!
I would try blowing it out first, I had that problem from transporting it home, blew it out and away it went.
Greenie, Grayling, SS stand alone BS and BS SPT, jointer and belt sander, 3 Ers with Speed Changers. I think those 3 cover my ER needs, and space for them.![Smile :)](./images/smilies/smile.gif)
![Big Grin :D](./images/smilies/biggrin.gif)
I use a finger nail file (emory board) to clean and polish the start winding points. A multimeter (ohm scale) can be used to check if the points are making contact when the motor is not operating. I remove and then reconnect the points wiring connectors as this can be a problem area.JPG wrote:disc42 wrote:Can you buy new ones.If so where.
This must be the original motor because all the connections are soldered on.I checked switch with a meter and it shows open.I,ll have to remove it anyway because the insulation is coming off the wires that go to the winding and capacitor.
- greasemonkey2275
When I rebuilt my Greenie I was having a similar problem with my 3/4hp motor. I sanded the contacts with an ignition points file and also found that the two arms were not making initial contact when power was first applied so you might want to check there as well. I posted the video on youtube if you want to take a look. https://www.youtube.com/watch?v=J4k50w666KU
Jake
Spokane, WA
Spokane, WA
