Space between tubes on the main table for model 510
- reubenjames
Does anybody know, or is anyone near enough to measure, the space between the two rack and pinion mounting tubes on the Mark V 510 main table? The purpose of the question is in regard to under-SS storage options--I want to be able to lower the table without the storage getting in the way of the tubes. I won't be home until late tonight, so won't get a chance to measure until tomorrow afternoon.
Re: Space between tubes on the main table for model 510
From memory I used 14" when I built an under storage unit but again from memory I think you could go just a bit wider, perhaps 14-1/4. We just got back from shopping and I have to get some lunch and then if no one has checked in with new numbers I will go out and measure to be sure.
Yes you have about 14-1/4 from inside leg to inside leg. So my memory was pretty good.
- reubenjames
Nice. Thanks, Ed!
Alec S.
1985 Mark V upgraded to 520 and Power Pro (SN 000527)
1983 Mark V Shop Deputy (SN 163487)
1982 Mark V headstock (SN 122265)
1949 (?) 10 ER in transition to dedicated drill press (SN 18677)
11" Band Saw (Aluminum Table System upgrade) (SN 34026)
4" Jointer (SN 02-18-98)
6" Belt Sander (SN 19012)
18" Jig Saw (SN 17407)
20" Scroll Saw (SN 010593)
12" Thickness Planer (SN 10406)
Strip Sander (SN pending)
DC3300 Dust Collector (SN 102088)
