Waxing the machine
Waxing the machine
Hi
Now, a question regarding Nick's videos. I have noticed that any time Nick puts on the Johnson's paste wax, he just puts it on and never allows time for it to dry. I would think that process allows for a buildup of wax and sawdust. I always let it dry and then buff it off. What do you folks do?
Thanks
GeorgeM
Thanks
GeorgeM
Re: Waxing the machine
Letting it 'dry' would allow for a thicker coat prior to polishing. However the more you polish, the less remains(the coat gets thinner).
I think for storage, apply and polish only when taken out to use. Otherwise apply and polish. The solvents will dissolve the existing coat.
I like to let it 'dry' for a minute or two and minimally 'polish'.
My experience is that time makes no difference. A slick surface is the result of no time drying and also hours drying. All I ever wanted from the wax is a slick surface (also tubes and legs and headstock).
Applying and wiping right away needs no buffing, but works to make slick. Applying and waiting needs buffing and takes more time. This may leave a little more wax on the surface, but can't tell any difference between the two methods for slickness.
I have done both methods/
I treat it like paste car wax. Let it dry to a haze, then buff.
Bruce wrote:I treat it like paste car wax. Let it dry to a haze, then buff.
That makes two of us.
And now three.reible wrote:Bruce wrote:I treat it like paste car wax. Let it dry to a haze, then buff.
And since I started this thread, that makes 4!jsburger wrote:And now three.reible wrote:Bruce wrote:I treat it like paste car wax. Let it dry to a haze, then buff.
GeorgeM
I've tested liquid car wax which the directions specify allowing the wax to lightly haze over on my truck. I followed the directions as directed and also tried rubbing on and immediately wiping back off.
Not sure of any technical results however, When I applied water to the two sections, They appeared to bead and shed water exactly the same.
The most important thing here is the fact, We're discussing something I wish more folks would engage in. Protecting our equipment!!!!
I'm not the worrying kind of guy. I put some on when things don't move smoothly anymore.
I may be all wet here, but some years ago, there were posts on here to not apply car wax on the tables. The posts conveyed that some of the chemicals would transfer from the table to the wood and interfere with finishing of the wood.
