Computer Tip That Might Interest Some of You
db5
Post by db5 »
In my Documents list in Windows 7 as well as on my desktop I have folders. To easily access them visually I use icons (.ico files), e.g., anything Shopsmith has their logo, eBay has theirs, etc. I have a folder containing a list of ico (icon) files as well.
There is a simple procedure for converting jpg files to ico files and then for changing a folder to that icon on your desktop or in document folders elsewhere. If there is an interest in this procedure I can post it here as a pdf file.
Re: Computer Tip That Might Interest Some of You
Proceed! :cool:
wa2crk
Post by wa2crk »
Indeed, proceed.
BIll V
garys
Post by garys »
Linux Mint does the same thing except it wants the files in .png format instead of .ico
garys wrote:Linux Mint does the same thing except it wants the files in .png format instead of .ico
That is because the .ico format is a proprietary MS format isn't it?
garys
Post by garys »
.ico appears to be the format Microsoft uses, but I see it used everywhere on the web to display favicons on sites, so it isn't restricted just to Windows use.
.png appears to be more of an open format, so that is likely why Linux distributions chose to use it.
db5
Post by db5 »
wa2crk wrote:Indeed, proceed.
BIll V
Okay, I'll put something together and post HERE, not as a separate post. So, if your are interested look HERE.
Since Linux has a separate requirement I can't help but perhaps a Linux user can.
db5
Post by db5 »
let me know if you have problems with this and I'll make an attempt to adjunct accordingly. Accordingly means if I have the time or inclination.
How to Create Icons.pdf
(109.11 KiB) Downloaded 612 times
rjent
Post by rjent »
db5 wrote:let me know if you have problems with this and I'll make an attempt to adjunct accordingly. Accordingly means if I have the time or inclination.
Worked perfectly! Image
Dick
1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
