Mark V 510 Connector Tubes
JohnH
Post by JohnH »
I have just bought a 2002 version 510 with a shedload of accessories but unfortunately no connector tubes for joining the tables to give a larger work surface. Can anyone tell me the diameter of these tubes so I can try to find some tubing locally to do the job? Spares are tricky to find here in the UK. Thanks.
Re: Mark V 510 Connector Tubes
JohnH wrote:I have just bought a 2002 version 510 with a shedload of accessories but unfortunately no connector tubes for joining the tables to give a larger work surface. Can anyone tell me the diameter of these tubes so I can try to find some tubing locally to do the job? Spares are tricky to find here in the UK. Thanks.
1" od.
JohnH
Post by JohnH »
Thanks for that. I will find some 1" steel pipe tomorrow.
garys
Post by garys »
Grainger sells nice heavy wall stainless steel tubing that stays rust free forever.
https://www.grainger.com/product/Tubing ... Pid=search
garys wrote:Grainger sells nice heavy wall stainless steel tubing that stays rust free forever.
This would make for some really nice extension tubes but it is rather expensive.
The wall thickness is significantly greater ( about .093 thicker). If they are straight to begin with, they should stay straight. My extension tubes all have a slight bend. That is to say "they do not roll flat".
garys
Post by garys »
I bought two of the stainless tubes from Grainger a few years ago. They work perfectly and they have stayed nice and straight with use.
swampgator
Post by swampgator »
OK. Dumb question. Yes, there are dumb questions! :cool:
For a temporary measure, could you turn some tubes from a good hard wood?
Steve, the old swampgator
swampgator wrote:OK. Dumb question. Yes, there are dumb questions! :cool:
For a 'temporary measure', one could use 3/4" EMT, but what is available 'over there'?
sehast
Post by sehast »
Are these tubes straight? I would be tempted to try them if they are better than the stock shopsmith ones.
moiramph
Post by moiramph »
Also, there is seller in the UK that may have some available. Martin Supplies, LTD.
http://martins-supplies.co.uk/presta/
